Dynamically Linked Nested Sequence No Audio
Jun 25, 2013 9:51 AM
When I dynamically link a nested sequence from PPro, I have no audio in the timeline. Is this normal?
    Jun 25, 2013 10:03 AM   in reply to MannyEdwards
    No. If you have audio in the PR sequence (and it is not muted), you should have it in Encore when dynamically linked.
    Do you see an audio track in the Encore timeline?
    Jun 25, 2013 10:45 AM   in reply to MannyEdwards
    I assume CS6; true?
    How do you know it is empty? Is it just that it is silent?
    I did a very short test (6 second of bars and tones, nested that sequence in PR, DL from EN to that sequence). It played on the first 2 seconds. I played the sequence in PR, then it played all of it in EN.
    Encore conforms audio, and I wonder if there is something going on with that. I did the process over with new nest, and waited for about one minute. Played all the way through. My other theory was that rendering the new nest in PR would help, but that did not appear necessary.
    Jun 25, 2013 11:36 AM   in reply to MannyEdwards
    Does not sound "normal." I did not see conforming in the progress panel. But I had an audio track as soon as the timeline was added, even if it did not play fully.
    What kind of audio in PR? Source, sequence, nested sequence?
    Another way to sort this out is to export a 10 second bit from the PR nested sequence as MPEG2-DVD. This will produce m2v and wav files. Does the wav import to Encore okay?
    Jun 25, 2013 1:27 PM   in reply to MannyEdwards
    Thanks for reporting the work around.
