NBrumberger
Adobe Bridge CS6 Crashes.
Jun 25, 2013 4:25 PM
Tags: #error #bridge #crash #cs6
I am having a problem with Adobe Bridge in CS6.  After running it for a while it mysteriously crashes.  Here is a dump of the error report.  I never had this in CS5.  I am running Windows 7 64bit.  This can occur whether or not I am running any other applications at the same time.
How can I fix this? Can I remove and re-install just Bridge?
Neil
Log Name:      Application
Source:        Application Error
Date:          6/25/2013 2:20:42 PM
Event ID:      1000
Task Category: (100)
Level:         Error
Keywords:      Classic
User:          N/A
Computer:      Tachyon
Description:
Faulting application name: Bridge.exe, version: 5.0.2.4, time stamp: 0x50d9a019
Faulting module name: Bridge.exe, version: 5.0.2.4, time stamp: 0x50d9a019
Exception code: 0xc0000005
Fault offset: 0x0000000000a289b4
Faulting process id: 0x15fc
Faulting application start time: 0x01ce71e9c66472cc
Faulting application path: C:\Program Files\Adobe\Adobe Bridge CS6 (64 Bit)\Bridge.exe
Faulting module path: C:\Program Files\Adobe\Adobe Bridge CS6 (64 Bit)\Bridge.exe
Report Id: 16ae8091-dddd-11e2-bad4-902b345dfa05
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="Application Error" />
    <EventID Qualifiers="0">1000</EventID>
    <Level>2</Level>
    <Task>100</Task>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime="2013-06-25T21:20:42.000000000Z" />
    <EventRecordID>9300</EventRecordID>
    <Channel>Application</Channel>
    <Computer>Tachyon</Computer>
    <Security />
  </System>
  <EventData>
    <Data>Bridge.exe</Data>
    <Data>5.0.2.4</Data>
    <Data>50d9a019</Data>
    <Data>c0000005</Data>
    <Data>0000000000a289b4</Data>
    <Data>15fc</Data>
    <Data>01ce71e9c66472cc</Data>
    <Data>C:\Program Files\Adobe\Adobe Bridge CS6 (64 Bit)\Bridge.exe</Data>
    <Data>16ae8091-dddd-11e2-bad4-902b345dfa05</Data>
  </EventData>
</Event>
    Jun 25, 2013 4:45 PM   in reply to NBrumberger
    A reinstall rarely solves problems.  Try resetting preferences.  HOld down Ctrl key and start Bridge.  You will get a reset window.
