designmo15
Change measuring tool units to feet Acrobat X Pro
Jun 26, 2013 6:30 AM
Tags: #pro #acrobat_9 #createpdf #measuring_tool
I am exporting CAD drawings to PDF and using the measuring tool. I'd like for the tool units to be feet instead of inches. Is this possible? I've already contacted Autodesk support and they tell me it's an Adobe issue.
    Jun 26, 2013 6:42 AM   in reply to designmo15
    It doesn't seem like it's possible to do it, no.
    Jun 26, 2013 9:12 AM   in reply to designmo15
    There's a bug, so you can get the numbers right but not the units.
    First, make sure 'Embed scale information' is turned on for the Acrobat ribbon > Settings dialog.
    That will ensure the units from the Model and Layout viewports are referenced in the PDF file (note this doesn't work with AutoCAD's own PDF export feature). If you have a 20-feet-diameter circle in the model, Acrobat will measure it as 20.0, but it won't say "20 ft".
    The measurement scale only exists in the context of a viewport, so other areas of a layout (title blocks, borders, even the printed scale indicator block) will be seen as 1:1 in paper space. The scaling factors on Output Manager and for the viewport itself have no effect - the circle will measure as 20 'model unit things' even though the size on the printed page will change.
