recycle4uhouston
how do I open a pdf in inDesign CC?
Jun 26, 2013 9:22 AM
Thanks!
    Jun 26, 2013 9:24 AM   in reply to recycle4uhouston
    You cannot open a PDF. You can place a pdf from the File menu.
    Mike
    Jun 26, 2013 10:12 AM   in reply to recycle4uhouston
    You can't do it directly in InDesign.
    You have to do it with one of two third-party utilities:
    PDF2Id - Recosoft
    PDF2DTP (Edit PDF in Adobe InDesign or QuarkXPress) - Markzware
    Jul 11, 2013 7:04 PM   in reply to recycle4uhouston
    At present the only tool available that will convert a PDF to InDesign CC format and keep elements live and editable with the layout properly formed/retained is PDF2ID v4.0; built specifically for InDesign Creative Cloud.
    Jul 12, 2013 5:22 AM   in reply to Paul Chadha
    As a note, Paul is employed by Recosoft and may or may not be correct at this time regarding offerings from Markzware.
    Jul 12, 2013 5:43 AM   in reply to Peter Spier
    On the Markzware website, support is only listed for InDesign CS5, 5.5 and 6.
    Jul 12, 2013 6:35 AM   in reply to Steve Werner
    I would expect that to change in the not distant future, though, so users coming back to this thread later should not be under the impression that there willonly be one option forever and should check for themselves if they want to see waht's currently available.
    Jul 30, 2013 8:02 PM   in reply to Peter Spier
    Why after so many years, Indesign still couldn't open an PDF????
    I really need this function!
    Hopefully Adobe couldn't solve this problem in future version!
    Jul 31, 2013 12:59 AM   in reply to Lulu_Malaysia
    PDFs are designed to be a FInal file format. They are never intended to be edited in anyway.
    Adobe don't support this function for many reasons.
    InDesign, Illustrator, Photoshop or any other Adobe product is not a multi-purpose PDF editor and you shouldn't be opening a PDF in Illustrator or Photoshop unless that PDF was specifically made with those programs.
    To open a PDF in InDesign you need specialist software as mentioned above.
    The correct workflow is to edit the existing InDesign document.
    If you don't have that original InDesign document, then you need to recreate it from the start.
    If you don't want to do that - then you need to buy the software that Converts the PDF to InDesign.
    Jul 31, 2013 1:08 AM   in reply to recycle4uhouston
    What I'd like to know is why. What workflow are you using that needs this feature?
    Jul 31, 2013 1:15 AM   in reply to Sandee Cohen
    I'm in house designer who work with NGO,
    my colleagues likes to use Microsoft word to do proposal,
    which need to do some layout and design (which they have half way done),
    and send out for printing.
    Sometimes they need to amend PDF Booklet from other NGOs.
    This is why i need the "Open PDF" function.
    Jul 31, 2013 1:23 AM   in reply to Lulu_Malaysia
    If the changes are minor you can edit the PDF in Acrobat.
    Jul 31, 2013 1:33 AM   in reply to Sandee Cohen
    Acrobat can only do some minor amendment,
    but usually they will change language in whole book,
    Hopefully Adobe add this function in next version!
    Jul 31, 2013 1:39 AM   in reply to Lulu_Malaysia
    Don't think they will.
    If they need to make the ammendments why don't they do it in Word?
    Or if it was made from Word you can do a File>save as Microsoft Word
    Open it in word - make the changes and re-pdf it?
    They shoudn't be designing anything in Word either. They should send you the Word file.
    You design it and prep it for the printers.
    You need to look at your workflow and fix things so that you get a Word file, design it in InDesign and then make it a PDF for the printers.
    Jul 31, 2013 5:44 AM   in reply to Lulu_Malaysia
    Doubtful that Adobe will bother with this any time soon.
    You can buy one of two applications from Markzware or Recosoft to accomplish this now.
    Jul 31, 2013 8:53 AM   in reply to recycle4uhouston
    I represent Recosoft, the company that makes PDF2ID. If you have budget contraints and you require a PDF to InDesign solution that operates with InDesign CC, we have an Adobe Exchange store specific version of PDF2ID  which is reasonable in terms of pricing. Simply open up your Adobe Exchange panel in InDesign CC and you'll see it.
