Gwen Davis
Is there any possible way to retrieve a lost file?
Jun 26, 2013 3:38 PM
I have a MacBook Pro. I have been creating graphics with Flash, and the program shut down. Then it showed a recovered file, so I started to work in that. Then that disappeared and there is no trace of it. Is there ANYWHERE I might still retrieve it?
I have this in the address bar
RECOVER_Untitled-1_20130618151405.fla*
Will this info let me find the file, or some version of it?
  • kglad
    Jul 21, 2002
    Jun 26, 2013 4:41 PM   in reply to Gwen Davis
    search for fla files.
    if you have a working swf, you may be able to decompile it and create a working fla.
    and, if you find even a corrupt fla, don't delete it.  you may still be able to extract, at least, some of your assets.
    Jun 26, 2013 9:37 PM   in reply to Gwen Davis
    Did you close the recover file without saving by any chance????
    Jun 26, 2013 10:17 PM   in reply to Gwen Davis
    If you have swf corresponding to that file  like kglad said, you can import swf to Flash CS6 and recover you assets.
    Jun 26, 2013 10:21 PM   in reply to Sangeeta J Yelamali
    Just check the folder ~/Library/Application Support/Adobe/Flash CC/en_US/Configuration folder if you had never saved the file, otherwise you can check the folder where the original version of the file was saved and you had some unsaved changes.
    Jun 26, 2013 10:23 PM   in reply to dharmk
    You can also check the file AutoRecoveryFilenames.txt under ~/Library/Application Support/Adobe/Flash CC/en_US/Configuration. That'll have the full path of all the auto-recovery files saved by Flash.
