• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
how to use Baskerville bold italic font in iOS?
Engaged ,
Jun 26, 2013 Jun 26, 2013
So I want to use bold italic Baskerville. No matter what I do, it always shows up as regular in the device (without bold or italic). My code works fine on desktop.
I've tried using TextFormat class properties, which work for fonts like Georgia or Helvetica, but it doesn't for Baskerville.
textFormat.font = "Georgia";
textFormat
.bold = true;
textFormat
.italic = true;
I've also tried using the official iOS name of the font which is "Baskerville-BoldItalic" nothing.
I've listed all the fonts using this
var allFonts:Array = Font.enumerateFonts(true);
And it only lists the regular fonts, no bold or italic versions.
Any ideas on how to make Baskerville render in bold or/and italic?
TIA
TOPICS
Development
Views
2.7K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Engaged ,
Jun 27, 2013 Jun 27, 2013
Bump
Votes
Translate
Translate
Report
Report
Engaged ,
Have you tried setting the font to "Baskerville Bold Italic" with the bold and italics flags set to false?
Votes
Translate
Translate
Report
Report
Engaged ,
Yes. I have tried all possible combinations...
Votes
Translate
Translate
Report
Report
Engaged ,
Ok, I asked this one specifically because I am using that name with the Text Layout Framework on an iOS app and it works.
Votes
Translate
Translate
Report
Report
Engaged ,
I'm using the Textfield class, and TextFormat class. I do not want the extra overhead of using TLF.
Anyway I will try with TLF and get back to you.
Votes
Translate
Translate
Report
Report
Engaged ,
Well it seems I'm out of luck. I'm using Flash CC, and there is a bug. I cannot import the class, because some SWC is missing.
import fl.text.TLFTextField;
And that throws the error:
1017: The definition of base class TLFTextField was not found.
I've already filled a bug report in bugbase...
https://bugbase.adobe.com/index.cfm?event=bug&id=3586600
Votes
Translate
Translate
Report
Report
Engaged ,
Wait a minute...
Are you using an Embed font or a Device font?
Votes
Translate
Translate
Report
Report
Engaged ,
No, I'm talking about all device fonts on iOS. I am using the text layout framework with device fonts. I am using FlashBuilder though, not Flash CC, not sure what SDK or swc libs you get with Flash CC.
Votes
Translate
Translate
Report
Report
Engaged ,
Well the answer is simple. TLF text has been deprecated... and removed from Flash CC.
http://help.adobe.com/en_US/flash/cs/using/WSb03e830bd6f770ee-4b0db644124bbdb363d-8000.html
So I cannot use TLF text. Great.
Do you have any experience with embed fonts in iOS? I'm under the impression that embeding is not very good performance wise.
Votes
Translate
Translate
Report
Report
Engaged ,
Well I don't know exactly how you are using fonts or text in your app, but TLF can still be used, it is part of apache-flex with newer builds
http://flex.apache.org/
But I don't know anything about how/if it integrates the way you need in Flash CC.
I don't see a problem with the embedded fonts I use, but my apps are also Stage3D not Flex components, using TLF to render text lines at the text engine Sprite level, not with Flex components.
Votes
Translate
Translate
Report
Report
Engaged ,
Thanks for the info.
I'll go with the embed route then, and cross fingers.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Hello,
Could you please open a new bug report on this over at bugbase.adobe.com? Once the bug has been added would you mind posting back with the URL so that others affected can add their votes and comments?
Nimit
Votes
Translate
Translate
Report
Report
Engaged ,
Jun 28, 2013 Jun 28, 2013
LATEST
Hello, here is the bug report https://bugbase.adobe.com/index.cfm?event=bug&id=3587210
BTW, I have tried embedding the font, and I got a new problem.... I've described my new problem in the flash forum and in StackOverflow.
http://forums.adobe.com/message/5457958#5457958
http://stackoverflow.com/questions/17356240/as3-font-embed-height-issue
Votes
Translate
Translate
Report
Report
