Looping through an array more that once
Jun 26, 2013 6:46 PM
I have simple array of movie clips that loop through once according to the code below:
private var  lettersL1:Array = [a,a,f,f,f,g,h,i,i,n,n,n,o,o,o,o,s,s,t,t,t];
          for (var i: Number  =0; i < lettersL1.length; i++)
                    trace (lettersL1[i]);
This works, but for my game to work I need the loop to run three times.
Of cause adding    i< lettersL1.length;    doesn't work. And I really would prefer not to hard code it with adding a number instead of .length.
What is the correct notation?
Charine
  • kglad
    Jul 21, 2002
    Jun 26, 2013 8:39 PM   in reply to Charine -FB buggoop
    use:
              for (var i:int  =0; i < lettersL1.length*3; i++)
                        trace (lettersL1[i%lettersL1.length]);
    Jun 27, 2013 9:36 AM   in reply to Charine -FB buggoop
    You might have missed the mod operator: ( lettersL1[ i % lettersL1.length] )
    Jun 27, 2013 9:54 AM   in reply to Charine -FB buggoop
    Hi Charine,
    you have missed the mod operator in the actual calls.
    lettersL1[i].x = 399;
    lettersL1[i].y= 30;
    addChild(lettersL1[i]);
    You can use the following:
    for (var i: Number  =0; i < lettersL1.length*3; i++)
              var index = (i%lettersL1.length);
              trace (lettersL1[index]);
              lettersL1[index].x = 399;
              lettersL1[index].y= 30;
              addChild(lettersL1[index]);
    Since there are only lettersL1.length number of elements in the array, the moment the value of i goes beyond the limit you'll not be able to retrieve any elements at that index from the array. Having an updated index ( i % lettersL1.length) fixes this issue.
    Regards,
    Dharmendra.
