Tall_CH
Anchor a custom master page
Jun 27, 2013 12:52 AM
Tags: #anchor #fm11 #custom_master_page
Is it possible to anchor a custom master page?.  I'm using a custom master page for rotated pages to adapt as well the header and footer but I want to use the same text flow. When I'm inserting something before the rotated page, it moves all the content. So text which should be on the rotated page moves then to the following normal pages.
By addressing the master page usage, I couldn't find any function which anchors it to the text like e.g. tables or anchored figures.
My system: Win7-64, FM11 (unstructered).
    Jun 27, 2013 5:41 AM   in reply to Tall_CH
    View > Master Pages
    Navigate to page MasterPageMaps
    Doesn't exist?
    Then do: Format > Page Layout > Apply Master Pages (AMP)
    This creates the page and an empty UnstructMasterPageMaps table.
    Designate a paragraph format (aka tag or style) that is unique to the rotated page content, such as Body.Rotated, which may wel be identical to Body in all but name.
    Assuming your rotated MPs are named Left.Rotated and Right.Rotated, fill out the UnstructMasterPageMaps table, such as:
    Tag NameRight-HandedLeft-HandedRange IndicatorComment
    Body.RotatedRight.RotatedLeft.RotatedUntil ChangedTriggers landscape
    BodyRightLeftUntil ChangedResumes portrait
    Optimal trigger/resume tags are highly dependent on document structure and may require some experimentation.
    Once set up, you need to do a manual AMP operation for initial MP assignment, and periodically as re-flow occurs. You can do this as above, or from the Book menu (it's an Update Book option)
    Jun 28, 2013 1:31 PM   in reply to Tall_CH
    > For the Unstructured Masterpage Map, there is even the table in
    > german and english existing. I don't know if on table could be deleted or not.
    Save the content of the UnstructMasterPageMaps tables somewhere else.
    Delete master page MasterPageMaps.
    Perform an AMP to re-create it.
