How do I get RTL support in IND CC?
Jun 27, 2013 5:21 AM
Tags: #indesign #in #arabic #support #rtl #hebrew
Hi There,
I uninstalled InDesign CS6 and when I tried to install it back in Adobe App Manager I don't see it. Instead there were InDesign CC available. So, I install it. However the InDesign CS6 I had support RTL languages such as Arabic and Hebrew. I need it for some project that are still in work.
Now, for my surprise, InDesign CC do not have such thing. I am sure I did something wrong but I cannot understand what.
Please help me to solve the issue.
Regards,
Sebastian
    Jun 27, 2013 5:58 AM   in reply to sebdea
    To reinstall CS6 if you have the Creative Cloud installed, go to: creative.adobe.com.
    Click on Download Center. Scroll down to InDesign and click Download. About the middle of the InDesign CC page, under the heading "In This Version" there is a popup menu where you can choose InDesign CS6.
    In either version, to use RTL, you need to use the World Ready Composer. However, to properly punctuate RTL and compose stories, you also need to use an additional plugin like World Tools (which probably isn't available yet for InDesign CC).
    Jun 27, 2013 6:09 AM   in reply to sebdea
    Just a second. It's very easy to download the Middle Eastern version of
    InDesign CC (and all the other apps).
    Open the Creative Cloud app on your desktop. Then go to Preferences (the
    cog-wheel icon)>App, and under the "App Language" dropdown, select the
    version you want. If you want Hebrew, select English תומך עברית
    That's it. Now when you install the application, the version you have
    asked for is installed.
    Ariel
    Jun 27, 2013 7:03 AM   in reply to sebdea
    Sebastian,
    Please delete your auto-signature and personal info when you reply by email. Thanks.
    Jun 27, 2013 8:27 AM   in reply to sebdea
    Just adding my two cents..
    You can certainly use the rtl text with InDesign CC English version too, although many capabilities that you will get installing the ME version will not be there the basic working can be implemented.
    All you need to do in go to Indesign preferences -> Advance Type
    Change the composer to - > Adobe World Ready paragraph Composer
    Then once you enable your keyboard to type a rtl language and select a font such as adobe Arabic or adobe Hebrew you can type RTL in Indeisng CC.
    Hope it helps
    Jun 27, 2013 8:32 AM   in reply to Ankit Kanwara.
    However, based on what I watched of Diane Burns' excellent Lynda.com video on Multilingual Publishing on Lynda.com, turning on the Adobe World Ready Composer is not sufficient to handle punctuation correctly (it appears at the wrong side of a line), and doesn't handle RTL story text flow properly. You have to have the addition of a plug-in like Harbs' World Tools to have all the features of the ME version.
    Jun 27, 2013 9:59 AM   in reply to sebdea
    Hi Sebastian,
    Yes, you normally would only want one version of InDesign 9 (CC) on your
    computer, so it's best to uninstall it, and then reinstall the ME version.
    Steve, since now with the Creative Cloud everyone can get the ME version
    with RTL support of InDesign for no extra cost, I think the workarounds
    you're mentioning are moot points. Anyone who wants the best available
    options for setting RTL texts should simply install the ME version of
    InDesign CC. All the features of the regular version are there, plus a
    whole bunch of extra things useful for RTL texts. Nothing is lost, only
    gained.
    Ariel
    Jun 27, 2013 2:21 PM   in reply to sebdea
    You can have both CC and CS6 products installed at the same time. Here's how to reinstall the CS6 versions:
    Oct 16, 2013 9:40 AM   in reply to Ankit Kanwara.
    I desperately need some help here. I have InDesign CC installed with App Preference set to English תומך עברית and have set it up to work properly with the World Ready composer.
    My problem is that I cannot find the options to change charcter direction. My help searches show it in the paragraph palette and the character palette but I don't see it in either place. Is there something else I need to activate to show character direction options?
    Please advise -- this is urgent as I have a job to finish where I cannot properly change character direction.
    Thanks.
    Oct 17, 2013 7:58 AM   in reply to Cyndee M
    Hey Cyndee,
    If you have the ME version it should say "Middle Eastern Version " if you click Help -> About InDesign. So make sure you have the right version
    Secondly it is the Paragraph panel and not the Paragraph Style panel which has the option so make sure you are looking in the right place. You can refer to the help document that has explanation of the ME features in InDesign.
    Let us know if that helps or not.
    - Ankit
    Oct 18, 2013 2:51 PM   in reply to Ankit Kanwara.
    Thanks, that was it, I found it on my own. Despite the fact the App Preference had the right language setting, that version had not been downloaded. Now I've got it installed and all is fine.
