Photoshop CC -> performance down, memory usage up.
Jun 27, 2013 11:38 AM
Tags: #photoshop #cc #memory_usage #slow_performance
I recently switched to Photoshop CC.
I noticed performance was slow, memory usage was huge. At first I thought it might be because I was processing somewhat larger panoramas than previous ( eg merging 25 images at 21 MP each ).
Then my SSD drive crashed when the sysem ran out of memory, and I can't recover it.
I reinstalled Mac OSX 10.7.5 on the original HD and re-installed PS. Now my network bandwidth has jumped from under 1 GB uploaded per day, to 20GB, 30GB, 44 GB uploaded.
I don't know how much of this can be traced to PS CC, other than it's slow performance and high memory usage, but it' a suspicious coincidence.
Tom Legrady
Replies 1 2 Previous Next
    Jun 27, 2013 12:37 PM   in reply to legrady
    Hi legrady,
    I'm moving this thread to the Photoshop General forum where you should be able to find better help than in the beginner forum.
    Jun 27, 2013 5:52 PM   in reply to legrady
    Photoshop isn't uploading much unless you tell it to (like sync preferences).
    And the only thing it download by default is Lens Profiles.
    The CreativeCloud app does most of the downloading, when you tell it to install new apps.
    MacOS does get really flaky when the OS volume runs out of space - that should be avoided if at all possible.
    And Photoshop CC doesn't have increased memory usage over Photoshop CS6.
    I think you're looking at some coincidences, or bugs we just haven't seen (like corrupt fonts, bad third party plugins, etc.).
    Jul 2, 2013 4:33 AM   in reply to legrady
    I'm having a very similar problem. Since switching to photoshop CC I can no longer successfuly edit multiple images as I was able to do in CS6.
    I have a Mac Pro running 24GB of memory, yet I'm running out due to Photoshop hording memory. Upon launch, Photoshop CC was using circa 1GB of memory, having processed 7 120mb raw image files as tiffs, the memory being used by photoshop has increased to a whopping 11.81GB of memory. Surely this is an issue with Photoshop CC?
  • Trevor Dennis
    May 24, 2010
    Jul 2, 2013 6:25 AM   in reply to MatthewPWright
    Matthew, I'm just wondering how much space you have on your OS drive, as per Chris's comment in the post before yours?  In these days of SSDs for OS and program files, people do tend to run very short, and that might be especially true of they have just subscribed to the full Creative Cloud package (although the 12 apps I installed came to a lot less than 10Gb).
    Jul 2, 2013 6:39 AM   in reply to Trevor Dennis
    Hi Trevor
    I've got about 80GB free on the boot drive so would be suprised if this is the issue. I think I've worked out the issue this morning whilst working on some wedding photos though - it appears that Photoshop CC is bagging all of the memory I've allocated to it, under the preferences. It is then swapping out between Active and Inactive memory threads.
    This appears to be a different behaviour to CS6 which only appears to use the memory if needed, not store it as inactive. As a result, CC slows down the whole system meaning things like Lightroom, iTunes, Safari etc have less to play with.
    Does anyone think that sounds plausible?
  • Trevor Dennis
    May 24, 2010
    Jul 2, 2013 6:52 AM   in reply to MatthewPWright
    I'm using Windows 7, and I honestly don't think I've seen anything like that happen.  Here you go.  I've just ramped Photoshop up to 80%, and the whole system is using <6Gb of 32Gb installed RAM.  I have several other things open, and the computer has been on for two days.  The only time I ever have to wait is when rendering out an export in Premiere Pro.
    Jul 2, 2013 8:40 AM   in reply to Trevor Dennis
    Ive not experienced it before either - my settings don't look far off your's - the last time I checked, Photoshop CC was taking up 16.1GB!
    Thanks for taking the screen shots - doesn't look like it's brought me any closer but at least it rules out any issues I may have with set up within Photoshop CC itself, which is really useful.
    Jul 2, 2013 9:29 AM   in reply to MatthewPWright
    The memory behavior of Photoshop CC is identical to Photoshop CS6 (and CS5, CS4, etc.).
    We haven't seen any major leaks in Photoshop CC (and we did a BIG pass on our code to clean out even obscure leaks during CC development).
    But again, it is possible you are seeing something that we have not, due to external factors such as corrupt fonts, third party plugins, or third party utilities (anybody remember the misnamed "memory optimizers" from a few years back ? ).
  • Noel Carboni
    Dec 23, 2006
    Jul 2, 2013 10:45 AM   in reply to legrady
    I vote coincidence - for me Photoshop CC is just as fast as and uses the same number of resources as Photoshop CS6.
    -Noel
    Aug 13, 2013 3:09 AM   in reply to legrady
    I have same problem on Mac.
    After closing my documents without quiting the app,
    memory usage does not decreace.
    I try to confirm with cleanning the histories and clipboard,
    but the usage did not changed.
    It occurs every time.
    I don't use any plug-ins.
    Aug 13, 2013 2:32 PM   in reply to GoroMatsumoto
    That's not a problem -- memory usage is not supposed to decrease when you close documents.
    Photoshop allocates memory up to the limit you set in preferences, then reuses that memory.
    Photoshop won't release the memory until the OS needs it (paging), or you exit photoshop.
    Aug 13, 2013 3:42 PM   in reply to Chris Cox
    @Chris
    No.
    On my machine, PhotoshopCC eats huge memory compared with lower versions,
    it doesn't release after closing docs. And my machine become very very slow.
    CS6 and CS5 don't show this problem on same PSD.
    Aug 15, 2013 1:28 PM   in reply to GoroMatsumoto
    Again, it is not supposed to release memory after closing documents.
    And it worked the same way in previous versions.
    If Photoshop CC is using more memory than previous versions, check your preferences, disable third party plugins, then check for system problems (bad fonts, bad utilities, etc.).
  • Noel Carboni
    Dec 23, 2006
    Aug 15, 2013 8:43 AM   in reply to GoroMatsumoto
    You need to listen to Chris.  Photoshop has always held onto the RAM it has allocated.
    If you think it didn't then you are mistaken.
    This strategy optimizes Photoshop's performance at some possible detriment to the other applications on your system.
    You choose how much RAM to allow it to grab in the Photoshop Performance preferences.
    -Noel
    Aug 16, 2013 3:04 AM   in reply to GoroMatsumoto
    atsuhashi wrote:
    @Chris
    No…
    Are you pretending to argue with a top Adobe engineer who has been writing Photoshop code since the last millennium?
    Aug 16, 2013 3:23 AM   in reply to station_two
    Do your works.
    Aug 16, 2013 3:29 AM   in reply to GoroMatsumoto
    Sep 17, 2013 3:38 AM   in reply to Noel Carboni
    I second this, it's been doing this on my OSX system for a long time. When working with files above 1Gig you'll have to restart the program like every half hour. I'd really like to see this fixed...
  • Noel Carboni
    Dec 23, 2006
    Sep 17, 2013 6:04 AM   in reply to Wetouch
    Wetouch, it sounds as though you don't have a system with enough resources to do all the things you want to do simultaneously, or that you haven't set Photoshop's memory usage limit properly.
    With a sufficiently powerful system with enough RAM one certainly does not have to "restart the program like every half hour".
    It's true that Photoshop allocates memory and holds onto it - as I mentioned, this is to optimize operation for Photoshop itself.  But this is its basic design, and I can assure you there is no "fix" to its basic design forthcoming.
    Perhaps you should describe what it is that your system becomes unable to do after a half hour.  It could be you're a simple configuration change away from not having to "restart the program every half hour".
    -Noel
    Sep 18, 2013 9:13 PM   in reply to legrady
    Yes, this is ridiculous. I was having some relatively minor issues with Bridge CS6 but am now on a different subscription and decided to switch to Bridge CC and Photoshop CC.  Big Mistake.  Pretty much made the problems worse and PS takes forever to load and open photos from Bridge.  I just doubled my RAM to three weeks ago and now it looks like I will be needing even more of it.  Adobe needs to get their act together.
    Sep 19, 2013 12:14 AM   in reply to booey
    If Photoshop is taking more than 20 seconds to load... something is wrong with your system.
    (and 20 seconds is on the worst laptop we can still boot, normal launch is under 7, and with an SSD it's under 2 seconds)
    Oct 10, 2013 4:36 AM   in reply to Wetouch
    Same problem over here!
    Come on adobe take your resposibility and fix thsi asap.
    Adobe CS6 on teh latest Mac...
  • Noel Carboni
    Dec 23, 2006
    Oct 10, 2013 8:25 AM   in reply to Robbert van Schravendijk
    Robbert, do you have any 3rd party plug-ins installed?
    Did it always take a long time to start up or did something change?
    Could you please go into Photoshop and choose Help - System Info, copy the data, and post it here.
    Don't assume that complete responsibility for integrating software on your computer and make everything work well lies solely with someone else.
    -Noel
    Oct 10, 2013 8:29 AM   in reply to Noel Carboni
    Hi Noel,
    I dont have 3rd party plugins installed.
    Just the regular photoshop from the suite.
    I have memory keeper to check memmory usage, and photoshop is eating it all.
    Adobe Photoshop Version: 13.0.5 (13.0.5 20130521.r.44 2013/05/21:21:00:00) x64
    Operating System: Mac OS 10.8.5
    System architecture: Intel CPU Family:6, Model:42, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
    Physical processor count: 4
    Logical processor count: 8
    Processor speed: 2200 MHz
    Built-in memory: 8192 MB
    Free memory: 4197 MB
    Memory available to Photoshop: 6870 MB
    Memory used by Photoshop: 65 %
    Image tile size: 1024K
    Image cache levels: 4
    OpenGL Drawing: Enabled.
    OpenGL Drawing Mode: Advanced
    OpenGL Allow Normal Mode: True.
    OpenGL Allow Advanced Mode: True.
    OpenGL Allow Old GPUs: Not Detected.
    OpenCL Version: 1.2 (Apr 25 2013 18:32:06)
    OpenGL Version: 2.1
    Video Rect Texture Size: 16384
    OpenGL Memory: 496 MB
    Video Card Vendor: ATI Technologies Inc.
    Video Card Renderer: AMD Radeon HD 6750M OpenGL Engine
    Display: 1
    Main Display
    Display Depth: 32
    Display Bounds: top=0, left=0, bottom=1200, right=1920
    Video Renderer ID: 16915206
    Video Card Memory: 512 MB
    Serial number: 92299704159996263038
    Application folder: /Applications/Adobe Photoshop CS6/
    Photoshop scratch has async I/O enabled
    Scratch volume(s):
      Macintosh HD, 465,0G, 95,7G free
    Required Plug-ins folder: /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/
    Primary Plug-ins folder: /Applications/Adobe Photoshop CS6/Plug-ins/
    Additional Plug-ins folder: not set
    Installed components:
       adbeape.framework   adbeape   3.3.8.19346   66.1025012
       AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.2.29.18602   66.490082
       adobe_caps.framework   adobe_caps   6.0.29.0   1.276181
       AdobeACE.framework   AdobeACE   2.19.18.20743   66.507768
       AdobeAGM.framework   AdobeAGM   4.26.20.20743   66.507768
       AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
       AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.7.101.18636   66.26830
       AdobeBIB.framework   AdobeBIB   1.2.02.20743   66.507768
       AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   66.507768
       AdobeCoolType.framework   AdobeCoolType   5.10.33.20743   66.507768
       AdobeCrashReporter.framework   AdobeCrashReporter   6.0.20120720
       AdobeExtendScript.framework   AdobeExtendScript   4.2.12.18602   66.490082
       AdobeJP2K.framework   AdobeJP2K   2.0.0.18562   66.236923
       AdobeLinguistic.framework      17206
       AdobeMPS.framework   AdobeMPS   5.8.0.19463   66.495174
       AdobeOwl.framework   AdobeOwl   5.0.4   79.517869
       AdobePDFL.framework   AdobePDFL   10.0.1.18562   66.419471
       AdobePDFSettings.framework   AdobePDFSettings   1.4
       AdobePIP.framework   AdobePIP   7.0.0.1686
       AdobeScCore.framework   AdobeScCore   4.2.12.18602   66.490082
       AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
       AdobeXMP.framework   AdobeXMPCore   66.145661   66.145661
       AdobeXMPFiles.framework   AdobeXMPFiles   66.145661   66.145661
       AdobeXMPScript.framework   AdobeXMPScript   66.145661   66.145661
       ahclient.framework   ahclient   1.7.0.56
       aif_core.framework   AdobeAIF   3.0.00   62.490293
       aif_ocl.framework   AdobeAIF   3.0.00   62.490293
       aif_ogl.framework   AdobeAIF   3.0.00   62.490293
       AlignmentLib.framework   xcode   1.0.0.1
       amtlib.framework   amtlib   6.0.0.75
       boost_date_time.framework   boost_date_time   6.0.0.0
       boost_signals.framework   boost_signals   6.0.0.0
       boost_system.framework   boost_system   6.0.0.0
       boost_threads.framework   boost_threads   6.0.0.0
       Cg.framework   NVIDIA Cg
       CIT.framework   CIT   2.1.0.20577   146758
       data_flow.framework   AdobeAIF   3.0.00   62.490293
       dvaaudiodevice.framework   dvaaudiodevice   6.0.0.0
       dvacore.framework   dvacore   6.0.0.0
       dvamarshal.framework   dvamarshal   6.0.0.0
       dvamediatypes.framework   dvamediatypes   6.0.0.0
       dvaplayer.framework   dvaplayer   6.0.0.0
       dvatransport.framework   dvatransport   6.0.0.0
       dvaunittesting.framework   dvaunittesting   6.0.0.0
       dynamiclink.framework   dynamiclink   6.0.0.0
       FileInfo.framework   FileInfo   66.145433   66.145433
       filter_graph.framework   AdobeAIF   3.0.00   62.490293
       hydra_filters.framework   AdobeAIF   3.0.00   62.490293
       ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
       ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
       image_compiler.framework   AdobeAIF   3.0.00   62.490293
       image_flow.framework   AdobeAIF   3.0.00   62.490293
       image_runtime.framework   AdobeAIF   3.0.00   62.490293
       LogSession.framework   LogSession   2.1.2.1681
       mediacoreif.framework   mediacoreif   6.0.0.0
       PlugPlug.framework   PlugPlug   3.0.0.383
       UpdaterNotifications.framework   UpdaterNotifications   6.0.0.24   "6.0.0.24"
       wrservices.framework
    Required plug-ins:
       3D Studio 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
       Accented Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Adaptive Wide Angle 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
       Angled Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Average 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Average.plugin”
       Bas Relief 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       BMP 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Camera Raw 8.2 (94), Copyright © 2013 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
       Camera Raw Filter 8.2 (94), Copyright © 2013 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
       Chalk & Charcoal 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Chrome 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Cineon 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©2002-2012 Adobe Systems Incorporated - from the file “Cineon.plugin”
       Clouds 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
       Collada DAE 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
       Color Halftone 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Colored Pencil 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       CompuServe GIF 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Conté Crayon 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Craquelure 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Crop and Straighten Photos 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©2003-2012 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
       Crop and Straighten Photos Filter 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Crosshatch 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Crystallize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Cutout 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Dark Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       De-Interlace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Dicom 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “dicom.plugin”
       Difference Clouds 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
       Diffuse Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Displace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Dry Brush 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Eazel Acquire 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©1997-2012 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
       Embed Watermark NO VERSION - from the file “DigiSign.plugin”
       Entropy 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Extrude 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       FastCore Routines 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “FastCore.plugin”
       Fibers 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Film Grain 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Filter Gallery 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Flash 3D 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
       Fresco 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Glowing Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Google Earth 4 KMZ 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
       Graphic Pen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Halftone Pattern 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       HDRMergeUI 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
       IFF Format 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Ink Outlines 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       JPEG 2000 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©2001-2012 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
       Kurtosis 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Lens Blur 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
       Lens Correction 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
       Lens Flare 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Liquify 13.0, Copyright © 2001-2012 Adobe Systems Incorporated - from the file “Liquify.plugin”
       Matlab Operation 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
       Maximum 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Mean 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Measurement Core 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
       Median 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Mezzotint 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Minimum 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       MMXCore Routines 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “MMXCore.plugin”
       Mosaic Tiles 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Multiprocessor Support 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
       Neon Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Note Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       NTSC Colors 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
       Ocean Ripple 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Oil Paint 13.0, Copyright © 2011 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
       OpenEXR 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Paint Daubs 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Palette Knife 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Patchwork 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Paths to Illustrator 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       PCX 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “PCX.plugin”
       Photocopy 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Photoshop 3D Engine 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
       Picture Package Filter 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
       Pinch 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Pixar 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “Pixar.plugin”
       Plaster 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Plastic Wrap 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       PNG 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Pointillize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Polar Coordinates 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Portable Bit Map 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “PBM.plugin”
       Poster Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Radial Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Radiance 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©2003-2012 Adobe Systems Incorporated - from the file “Radiance.plugin”
       Range 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Read Watermark NO VERSION - from the file “DigiRead.plugin”
       Reticulation 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Ripple 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Rough Pastels 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Save for Web 13.0, Copyright © 1999-2012 Adobe Systems Incorporated - from the file “Save for Web.plugin”
       ScriptingSupport 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
       Shear 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Skewness 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Smart Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Smudge Stick 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Solarize 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Solarize.plugin”
       Spatter 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Spherize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Sponge 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Sprayed Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Stained Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Stamp 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Standard Deviation 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       STL 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
       Sumi-e 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Summation 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Targa 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Texturizer 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Tiles 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Torn Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Twirl 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Underpainting 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Vanishing Point 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
       Variance 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
       Water Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Watercolor 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Wave 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Wavefront|OBJ 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
       Wind 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Wireless Bitmap 13.0.5 20130521.r.44 2013/05/21:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “WBMP.plugin”
       ZigZag 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
    Optional and third party plug-ins: NONE
    Plug-ins that failed to load: NONE
    Flash:
       Mini Bridge
       GuideGuide
       Kuler
    Installed TWAIN devices: NONE
    Oct 30, 2013 9:11 AM   in reply to legrady
    I recently "upgraded?" to CC at my office. I mainly use Photoshop and Dreamweaver. I have noticed a huge reduction in responsiveness. I work on a less than 1-year-old iMac, and since upgrading it take 5 minutes or more to open files that use to be relatively quick to open. I also am having slow save times. Just to manipulate text in a text box, sometimes causes the spinning color wheel to come op for 10 or more seconds. This kind of slowdown is affecting my productivity. What can I check to speed up my load times?
    Nov 15, 2013 11:14 AM   in reply to Aspeeder
    I have the same story with Adobe CC. I have Adobe CS5.5 on one system and CC on another. The file is ±400MB in size, and the CS5.5 uses 6-8GB of RAM while working on the file, while the CC uses 13-16GB of RAM on the same file.
    Both systems have 16GB RAM installed, and are allowing Photoshop to use up to 90%.
    I'm currently using 6 Cache levels and 1024 tile size.
    Nov 16, 2013 3:12 AM   in reply to legrady
    I've just 'upgraded' to Adobe CC purely because CS5 hadn't been updated by Adobe to open the new RAW files produced by my Nikon D600.  Naturally as I'm paying for the new version I have tried to use it but it runs amazingly slowly even though it is all set to run as CS5 was and I have sadly had to revert to CS5 for everything other than RAW processing.  Actions that run in CS5 without issue are laboured and slow in CC and after very little time a message simply appears saying that it can't function as there isn't enough RAM, something that hasn't ever happened with CS5.  Very disappointed to be spending out on the cloud for a product that doesn't work.  Have looked at Lightroom as an alternative but flaws in its layout and work processes mean I find it far more unsuited to RAW conversion than using CC or CS5...please get this memory usage problem solved!!!
    Nov 18, 2013 10:18 AM   in reply to Chris Cox
    I have always worked with super huge files, because my designers never throw anything away, but since the switch my system slowed down incredibly. my file size is 250M using 150M and I show I have 750GB Free. i don't think it's a memory issue. I do see there is a Background File activity but I think it is from Dreamweaver. any hints, tricks??
  • Noel Carboni
    Dec 23, 2006
    Nov 19, 2013 4:10 PM   in reply to Aspeeder
    Aspeeder, you have a system that has 750GB of RAM?
    Out of curiosity, what did you switch from?
    -Noel
    Dec 5, 2013 6:06 AM   in reply to Noel Carboni
    I'm experiencing the 'slowdown as well.
    recently updated from cs4 to cc being stumbled by it's huge slowdown.
    I work on a 2007 intel mac pro
    Processor  2 x 3 GHz Dual-Core Intel Xeon
    Software  Mac OS X Lion 10.7.5 (11G63)
    Videocard  ATI Radeon X1900 XT 512 MB
    memory  12 GB 667 MHz DDR2 FB-DIMM
    I limited the animations and cache use to 65%
    but the shear 'dunk' in my productivity has made me switch back to cs4
    Dec 30, 2013 4:11 PM   in reply to Chris Cox
    The memory usage returned back to me right after I closed photoshop. I just now went to preferences and made my 1tb external my scratch disk instead. I thought I was being hacked or something! Was completely draining all my memory down KBs! I don't use any 3rd party plug ins. Barely have time to lose the programs I have with the CC membership. I still love the product bc im learning but dude, it was literally murdering every single drop of the 25 GB I had on my hdd. Never seen a program do that. Now that I know that the scratch disk needs that much memory, I should be cool. Definitely wanted to see if anyone else was going through it. If I was a coder for the program, I'd be just as addamant as you.
    Jan 4, 2014 4:12 AM   in reply to legrady
    The fact that these techs are going to tell every single person that the problem with the memory being eaten up by photoshop CC is in their systems.
    The fact that these techs are going to keep telling people that the memory usage is the same as previous versions of Photoshop.
    I restored the latest version 17" model Macbook pro to its factory settings and replaced 8 gigs of ram with 16gigs and then did a new install of CC and I have to tell you that even if you set the preferences to 30% in Photoshop, it still eats 6 gigs without a document opened!  th bottom line is the more RAM addeed the more it takes.  I have been reading these posts since I subscribed to CC 4 months ago and nothing has changed. The Adobe specialists tell everyone that it is their system that is the problem and Photoshop is the same as it has always been.  Well I am sorry but, I find this unacceptable.  I am seriously thinking about getting rid of my CC membership because of what is happening. To me the difference between CC and CS5 is small.  Content Aware is the same to me whether it is CS5 or CC.  It is just sad that instead of finding a solution to this problem it is being denied instead. The fact is, we all need Adobe software because there is no other alternative so, we are at the mercy of those who tell us that the problem lies in our systems.
    Jan 4, 2014 10:13 AM   in reply to Dustin07
    That would be because the memory usage is about the same as previous versions, and we don't know of any major memory leaks in Photoshop CC (we do a lot of testing to find and eliminate memory leaks in Photoshop).
    And because we've seen third party drivers and third party plugins with memory leaks.
    If Photoshop consumes that much RAM without opening any documents - then you have about 6 Gigs of presets being loaded at launch (which is presets that you added, because by default Photoshop doesn't load that many presets, and consumes under 300 Meg at launch).
    If you mean that Photoshop cosumes that much after closing documents - then that is how much you allocated to Photoshop and used in your documents.  Photoshop not releasing memory back to the system until exit is perfectly normal behavior (otherwise it would run much slower).
    We can try to help you determine what is consuming memory on your system.
    But insisting that Photoshop is the cause when it is easily verified as not being the cause, won't help you.
    Jan 4, 2014 11:39 AM   in reply to legrady
    It is a sad state of affairs when the official response to all of these concerns about memory usage is 'it's your fault not ours'.  I've upgraded photoshop through each version from photoshop 7 and have never faced the issues that are occurring with CC.  If third party plugins and drivers affect Photoshop that badly then surely they should affect CS5 in the same way as they are affecting CC but I can assure you that my CS5 works perfectly and CC is unusable.  I, as many others in this discussion, feel that this is most certainly an issue for Adobe to solve, as long time Adobe users and supporters we deserve better service than this.  I am only able to use the RAW conversion element to CC (because CS5's version hasn't been updated to convert Nikon D600 or 800 RAW files) and once my tiffs or jpegs have been generated I then have to shut down CC and load up CS5 to work on them, I shouldn't be paying a monthly subscription to do that!
    Jan 4, 2014 11:45 AM   in reply to Chris Cox
    With 'no' add-ons, exept for 20 custom made brushes and 7 actions.
    Jan 4, 2014 5:01 PM   in reply to Chris Cox
    I don't know of any presets.  What I do know is that CS5 didn't do this and none of the other CC apps seem to do this.  (if I have a bunch of presets on Photoshop wouldn't I have the same problem with Illustrator, Indesign, Dreamweaver ect.?  All I am saying is this:
    There was no problem before PS CC.
    I am certainly not the only one with this problem.
    Out of all these threads I have yet to read about one person who has been given a valid solution that has solved this problem.
    I am aware that me being insistant isn't going to help me but maybe you could help me by giving me a valid reason why this is happening. Telling me your software is verified as not being the cause means nothing to me.  I am not a programmer or sofware developer.  How I come to my conclusions is simple. It's the reasoning that works for those of us who live in reality, not denial..... Simple deduction.
    Jan 4, 2014 5:40 PM   in reply to Dustin07
    I have no answers but if it were a "bug" then tens of thousands would be experiencing the problem.  In the past versions there have also been long threads on memory leaks by a few individuals.  Why some experience this and others don't is a mystery, so the logical explaination is that is a something specific with the users computer or settings.
    For Adobe to fix a problem they first have to be able to recreate it in the lab.  So far they have not been able to do this as far as I recall.
    I recently particiapted in a long thead "why is Bridge CC so slooooooow".  We tried various things but nothing worked.  He finallly just made a temp user and said the application just flies now.  Might try setting up another user account and see if anything changes.
  • Noel Carboni
    Dec 23, 2006
    Jan 4, 2014 6:08 PM   in reply to Chris Cox
    Chris, maybe you should give users the run-time option of having Photoshop do its memory management in the more conventional manner, where it releases the RAM back to the OS when it is through with it.
    If this means Photoshop runs slower, so be it.  They'll have their RAM for other things when Photoshop isn't actively using it.
    -Noel
1 2 Previous Next
Actions
