is there a Kaleidoscope plug-in for Pshop?
Jun 27, 2013 5:02 PM
Tags: #photoshop #mac #plugin #effect #generator #kaleidoscope #mandala
hi Folks,
I used Paint Shop Pro for years and they had a great Kaleidoscope generator effect built in to the program.
Switched to Pshop a couple years ago, and have been sorely missing the Kaleidoscope thing.
I've searched high and low on the 'net and there seems to be nothing out there.  Some freebies made for PC but nada for Mac.  (yes, i know there's some lame videos about how to do it in awesome awkward steps using mirroring and rotation and blah, blah, blah, but no, Martha, I'm not buying it.
Is it really a difficult programming feature to cook up one of these things?   I mean, hey, people are doing amazing stuff with fractal generators and computers, isn't about time someone coded a simple kaleidoscope plugin for Pshop on Macs?
thanks for any inspiration.
Gary
  • Trevor Dennis
    May 24, 2010
    Jun 27, 2013 6:23 PM   in reply to Bananzaman
    Not too hard to do with an action using Free Transform step & repeat.
    New square image - say 1500 x 1500 pixels
    View > New vertical guide 50pc  (50%)
    View > New hirizontal guide 50pc
    I'd also centre the grid to centre image
    Select the Polygon tool from the Shapes tools, and decide how many sides (it needs to be an even number to allow for mirroring)
    Start the Polygon from the centre, hold down the Alt (Opt) key, and rotate to keep the botton edge square to the image with help of the Guides.
    Make the Polygon with no fill and a 1 pixel stroke (from the options bar.
    Now you have a guide to make your first segment
    Draw that segment with the Pen tool, load it as a selection, and fill with white in a new layer
    Lock the transparency for that layer.   (This is the layer you draw your coloured shapes etc. on.)
    OK. Now you need to record your action so open the Actions panel.
    Select your segment layer, and Click on new Action > Give it a name, and shortcut (optional)
    Copy the layer (Ctrl j or Cmd j)
    Free Transform > select the centre top handle from the 3x3 grid left end of the options bar, and enter an angle (45° for eight segments) > Enter to commit
    Shift Ctrl Alt t (Shift Cmd Opt t)
    Repeat the above seven times
    End the action.
    OK.  Delete all the new segment layers, go back to the master segment, draw on it with fancy coloured brushes.
    Run the Kalidascope action.
  • Pierre Courtejoie
    Jan 11, 2006
    Jun 28, 2013 12:20 AM   in reply to Bananzaman
    Jun 28, 2013 3:20 AM   in reply to Bananzaman
    Maybe this old Script can help, but it’s not a proper plug-in.
    http://www.adobe.com/cfusion/exchange/index.cfm?event=extensionDetail& loc=en_us&extid=2145022
