CoryellBoy
Elements 9 install problem
Jun 27, 2013 3:40 PM
Tags: #mac #installation #elements_9 #photoshop_elements_9
I have used Elements 9 for some time on a Mac Air.  I used Apple's Migration Assistant to move all files to a new Air.  All went well except that when I try to open Elements, I get a message to the effect that it is missing some components, and should be re-installed.  When I try to do that, using my original CD, I get a message that the "Installer failed to initialize."
A similar question in this forum yielded the suggestion to use Disc 3.  I don't seem to have a Disc 3, nor remember ever having one.  Any ideas?
    Jun 27, 2013 4:04 PM   in reply to CoryellBoy
    Oy. You have made a boatload of trouble for yourself by trying to migrate PSE. You can never, never do that, since PSE is not a nice tidy package in accordance with the apple developer guidelines. The PSE installer is more like a shot of buckshot--it strews stuff all over your hard drive in places the migration assistant is not programmed to look, and you can never find all the bits and bobs you would need.
    You will need to start by downloading and running this:
    http://www.adobe.com/support/contact/cscleanertool.html
    Then manually hunt around and remove all the bits of PSE that you can find. Be sure to check not only the applications folder, but also the library at the top level of your hard drive>application support>adobe. (nb, spotlight will not do this search)
    Yes, if you bought PSE on disc, you will need to make a copy of disc 3 and copy those files to the Air. If you bought a download, go to the main page of adobe.com and click on My Adobe and work your way through the links there. If you're lucky you may still have a link to the download there, but they're only available for a limited time so you may be past it for PSE 9 now.
    Jun 27, 2013 8:04 PM   in reply to CoryellBoy
    Glad you were able to fix it.
