ccBeginner
Can't change the text color into black
Jun 29, 2013 9:54 PM
Tags: #mac #dreamweaver #html5 #dw #dreamweavercc
The default text color is blue. I tried changing the CSS rule on text color into black but it didn't work.
I also tried this [ code below]: but either options below didin't work.
#nav
     color:black; [ tried also #000];
Can someone help me on how to change the default text color. How how to override that default color later on if I want some of text to be in a color that I want. I know that changing color should just simply assigning color using css but maybe dreamweaver has different way of doing it.
Thank you.
    Jun 30, 2013 12:14 AM   in reply to ccBeginner
    Being as the DIV ID is nav, I can only assume this is your navigation link area.
    Whenever you have <a href="wherever.html">Link</a> you have to change your CSS.
    #nav a {
        color: #000;
    If you've got links, you MUST write the CSS for links, or they will default to blue unclicked, red hover and purple visited
    #nav a {
    #nav a:hover{
    #nav a:visited {
    #nav a.active {
    the last one is if you want to show visitors the page their on.
    Ex; <a href="wherever.html" class="active">Link</a>
    Jun 30, 2013 11:18 AM   in reply to ccBeginner
    For best cross browser results, use the following order to style your link classes: Link, Visited, Hover, Active, Focus  (LiVHAF).
    a  {text-decoration:none} /**any link**/
    a:link {color:black }          /**unvisited links**/
    a:visited {color:green }   /**visited links**/
    a:hover {color:red }       /**on mouse over**/
    a:active {color:yellow}  /**on click**/
    a:focus {color:yellow } /**on focus**/
    Incidentally, the Active state doesn't show which page you're on. It only shows briefly when the link is clicked.
    To show "you are here" menu highlighting, use a persistent page indicator.
    http://alt-web.com/Articles/Persistent-Page-Indicator.shtml
    Nancy O.
    Jun 30, 2013 11:50 AM   in reply to Nancy O.
    "active" DOES if you declare it as a class and NOT a state. .active vs :active
    Jun 30, 2013 11:52 AM   in reply to Mike M
    Sure, but then it's not a pseudo-class that shows automatically. You have to assign the active class manually.
    Jun 30, 2013 12:05 PM   in reply to MurraySummers
    That is very very true, but then I gave instructions for how to do that.
