DG Webs
Swiffy JavaScript error
Jun 29, 2013 9:54 PM
I've tried using Swiffy to convert an fla file to HTML5 and get the same error code with every fla file I try. Here is the error code:
I'm using Flash Pro CC on a Mac running OSX 10.8.4
Any ideas?
    Jun 30, 2013 5:13 AM   in reply to DG Webs
    You probably need to visit and find some help from the folks that make and/or use Swiffy.
    Jul 2, 2013 3:07 AM   in reply to DG Webs
    You have to locate the Export as HTML 5 (Swiffy).jsfl.
    When swiffy installs it will add this command somwhere on your harddisk. Probbaly under a folder that is named "commands" the exact location differs from OS to OS.
    Look at line 26 and report back
    Jul 3, 2013 12:15 AM   in reply to DG Webs
    As there is no good documentation about the swiffy internal workings (at least I found noting on googles site) at this point it becomes a wild goose chase. My first guess would be that it has to do with path-problems. If you are working on a network drive, try to change fla and htlm/js output to local storage, if you already compiling locally try a directory that is not nested deeply and were you are sure you have complete rights.
