Is there any  way to incorporate elements from the 2006 namespace in an application that uses the 2
Jun 30, 2013 11:06 AM
Tags: #air #xmlns:mx2006
I have a desktop app built in AIR using the 2009 namespace.  Is there any way to incorporate any of the of the xmlns:mx="http://www.adobe.com/2006/mxml" components into it?
Or better yet, since the AIR namespace is sort of layered on top of the spark namespace, is it possible to do the same with the 2006 namespace?
    Jun 30, 2013 10:39 PM   in reply to the0bot
    Most people map the "fx" prefix to 2009, then map mx to the following:
    xmlns:mx="library://ns.adobe.com/flex/mx"
    Then, if the mx.swc is in the project's library path, you should be able to use the mx: prefix like you did with 2006 except for places where "fx" is now used.
    Jul 1, 2013 7:42 AM   in reply to the0bot
    The code in the components did not change much for mx components in Flex 4 and later.  The skins changed, so if that's what you are concerned about, I think the old halo theme still exists.
    If I'm not understanding your questions, please provide an explicit example of what you want.
    -Alex
