Illustrator CC and CS6 doesn't start in Windows 8.1 Preview
Jun 30, 2013 6:07 PM
Tags: #illustrator #windows8.1
When I attemp to run Illustrator on my machine running Windows 8.1 preview I see this error message (In spanish because both my system and software language are in spanish):
Error
Esta aplicación no es compatible con el idioma del sistema operativo actual. Abra el Panel de control "Opciones regionales y de idioma" en el menú Inicio de Windows.
This application is not compatible with the curren operating system language. Open Region and settings in Control panel on Windows Start menu.
I tried switching to Spanish (Spain), Spanish (United Stated), English (United States) and back to Spanish (Chile) with no results.
Replies 1 2 Previous Next
    Jul 4, 2013 1:02 PM   in reply to Alexei Humeniy
    I'm having the same issue have you found any solutions?
    Jul 10, 2013 9:03 AM   in reply to Alexei Humeniy
    Me too, it seems to be a compatibility issue with windows 8.1
    Aug 1, 2013 5:20 AM   in reply to Alexei Humeniy
    The only fix around was to install the english version, hope adobe and microsoft find out whats causing this annoying bug
    Oct 6, 2013 8:40 AM   in reply to Alexei Humeniy
    I'm having the same problem using Windows 8.1 Pro RTM.
    Any solution? Thanks.
    Oct 17, 2013 10:28 AM   in reply to Alexei Humeniy
    I am having the same issue. I can't even use Illustrator it keeps shutting down. Is there a fix?
    Oct 17, 2013 12:38 PM   in reply to tschmidtinart
    Same problem here, we need a fix asap.
    Oct 17, 2013 2:52 PM   in reply to Alexei Humeniy
    Same here! Come on, we need a fix! Gonna try the english version for now, but hurry up please! This sucks.
    Oct 17, 2013 3:48 PM   in reply to Alexei Humeniy
    I'm having the same problem on the final version of Windows 8.1. I can't believe none hasn't fixed this already!
    Oct 17, 2013 9:02 PM   in reply to Alexei Humeniy
    Have you guys tried a reinstall? I have 8.1 on my machine as well and things are smooth. While upgrading 8.1 there was a question from Microsoft if I wanted to keep my application and settings, did you select that?
    Uninstall and reinstall works in most cases you should first try out that.
    Oct 18, 2013 7:25 AM   in reply to ADBEDesigner
    Hi!
    No, is not a language-match problem.
    I'm running Windows 8.1 in Spanish and Illustrator also in Spanish.
    Maybe the problem could be related with the regional settings. My Windows is set in "Spanish (Argentina)".
    Oct 18, 2013 7:33 AM   in reply to Rodrigo VAB
    Same here. Running illustrator in Spanish (Spain) and 8.1 in Spanish, and is not working.
    Oct 18, 2013 7:40 AM   in reply to Rodrigo VAB
    Same happend to me today..Please need a FIX now!
    It is incredible, that knowing this problem since long time ago they did not do nothing..
    This is our tool to work!!
    Hurry UP Adobe!!
    Oct 18, 2013 3:31 PM   in reply to Alexei Humeniy
    Glad I haven't installed the final version of Windows 8.1 on my work system running 8. I always wait some days before I install any important update If it comes with some bugs like this.
    This is very serious and Adobe has to fix it very soon.
    One question: Is this happening only on computers running Windows 8.1 X64 or it affects the 32 bit version too?
    Oct 19, 2013 1:08 AM   in reply to Alexei Humeniy
    English is definetly running wel on my computer. Is this a spanish only issue? is any non Spanish language build also seeing this issue?
    Oct 21, 2013 12:56 AM   in reply to ADBEDesigner
    Probably only happends with Spanish instalaton. Personally I only tryed with Spanish, Is the one I bought.
    Please give us a solution!
    Oct 21, 2013 2:40 AM   in reply to compegps
    I installed the english version(TRIAL) and it works, but...my license is for Spanish version!! why do I have to work with a trial version after paying(CS5 and CS6) license?
    To Adobe: FYI in this post (http://forums.adobe.com/message/5772460#5772460) is reported that it also works in Italian.
    Need a solution for Spanish Users
    Oct 21, 2013 5:10 AM   in reply to compegps
    Not even an answer from adobe. What a waste of time.
    Oct 21, 2013 6:34 AM   in reply to A123
    Have you called in support? This is actually a user to user forum, we do see Adobe folks from time to time but this is not a regular support forum.
    Oct 21, 2013 6:51 AM   in reply to ADBEDesigner
    Do you mean we are really wasting our time writng on this forum about this issue?
    Can you please give the support adress?
    Please do not send me here: http://helpx.adobe.com/contact.html
    Where is supposed we have to write or call??
    Oct 21, 2013 6:59 AM   in reply to compegps
    Offcourse you are not wasting your time here, if someone has a solution or a workaround you will get to hear fro other users.
    However answer to why has Adobe not responded or when will it be fixed will come only when you speak to representatives mentioned at the page that you do not  want to use.
    I have also received replies when I had sent email to ShareWithAI@adobe.com  you may want to try that. Make sure you write to them from the same email address that you used to purchase Adobe creative cloud lisence. OR have CS6 serial number of you are on perpetual lisence.
    Oct 21, 2013 9:00 AM   in reply to Alexei Humeniy
    I installed the Windows 8.1 upgrade on the weekend and can confirm the bug exists. The only way to keep working with Illustrator is installing the english version for now, while adobe take care of the issue.
    I already filled a bug report to adobe, hope this problem gets resolved as soon as possible.
    PLEASE ADOBE, FIX THIS ISSUE. Illustrator is our work tool to make a living!!!!!
    Oct 25, 2013 11:30 AM   in reply to Alexei Humeniy
    Hi everyone,
    First of all, our apologies for the inconveniences. Our team is aware of the incompatibility issue of Spanish WIN 8.1 RTM with Spanish Adobe Illustrator CC & CS6. We are currently working with Microsoft to investigate the issue and will be providing a fix as soon as possible.
    Meanwhile, for workarounds: http://helpx.adobe.com/illustrator/kb/illustrator-does-not-start-windo ws-81.html
    We'll let you guys know as soon as we have any updates.
    Amy
    Oct 22, 2013 2:03 PM   in reply to Alexei Humeniy
    Same with the english version. I have windows 8.1 and CS6 Illustrator crashes. Uninstalled and put CC still crashes.
    Oct 22, 2013 3:02 PM   in reply to Alexei Humeniy
    Same problem here. One question: how to download the English verion of Adobe CC??? Thanks.
    Posdata: we are in trouble because WE NEED give the artworks to customers. We paid for a software with years of good reputation. Adobe is the standard in the industry. But this issue is... frustating for us.
    We hope Adobe solve this soon.
    Oct 22, 2013 3:24 PM   in reply to ZityMap
    Hi ZityMap,
    Here's how to install the English version of Illustrator CC
    http://helpx.adobe.com/creative-cloud/kb/change-installed-language.htm l
    1. In the Creative Cloud app for desktop, click the gear icon on the upper right hand side and then choose Preferences.
    2. In the Preferences dialog box, click Apps.
    3. From the App Language list, select 'English (North America)' or 'English (International)'
    4. Go back to the App tab, reinstall Illustrator CC
    Let me know if you run into any issues.
    Oct 22, 2013 3:23 PM   in reply to Conisus
    Are you running the Spanish version of Win 8.1, Conisus?
    Have you tried resetting preferences (http://adobe.ly/Ty949V), disable any third party plug-ins and/or launch the software in a new user account with admin rights? http://helpx.adobe.com/x-productkb/global/troubleshoot-system-errors-f reezes-windows.html#main_Common_solutions
    If the basic troubleshooting steps don't work, would you mind to gather a copy of the crash log, paste it into http://pastebin.com and share the url? You should be able to locate the log by launching the Event viewer and search for the application crash logs of Illustrator.exe. Thanks!
    Oct 22, 2013 4:22 PM   in reply to ZityMap
    I down loaded the trial version from Adobe to get through, and will down load CS5 later on my machine.
    Oct 23, 2013 3:36 AM   in reply to amxyz
    Thanks. Adobe illustrator (English version) works. One question: how to know when Adobe fix the panish version issue? Any Newsletter will be sent? Thanks!
    Oct 23, 2013 6:23 AM   in reply to amxyz
    Have error code 1 now.
    Updated to 8.1. Illustrator loaded fine. Only when I inserted a jpg/png into the file and tried to save the progam closed.
    I uninstalled Illustrator CS6 and downloaded the trial version on CC, same error, just closed the program.
    Oct 23, 2013 7:17 AM   in reply to Conisus
    This error occurs in both Illustrator and After Effects CS6, the other programs of the Suite works perfectly. The time will have the solution for this problem?
    Oct 23, 2013 8:07 AM   in reply to amxyz
    Where can I find an Illustrator CS6 download that works? I uninstalled and tried to re-install from the adobe site files. Didn't work.
    Oct 23, 2013 10:16 AM   in reply to Conisus
    Hi Conisus,
    Error code 1 is often associated with permission issues. Have you tried installing Illustrator in a new user account with admin rights? If you wish to download CS6, here's how to get it through Creative Cloud: http://helpx.adobe.com/creative-cloud/kb/download-previous-versions-cr eative-applications.html
    Let us know how it goes.
    The Illustrator team is investigating the issue and will provide an update as soon as it's availabile. Again, sorry for the troubles!
    Oct 23, 2013 10:29 AM   in reply to amxyz
    I did that, but CC is all that showed up.
    Oct 23, 2013 10:53 AM   in reply to Conisus
    That's odd. Did you select the CS6 in the dropdown menu under 'In This Version'?
    If that doesn't work, try this link: http://helpx.adobe.com/x-productkb/policy-pricing/cs6-product-download s.html
    Please proceed to install this product as a trial and you should be able to license it after the installation is complete under Help.
    Oct 23, 2013 11:39 AM   in reply to amxyz
    When I go there I download 3 files and open them up. Illustrator_16_LS16.7z will not extract. One opens, Illustrator_16_LS16.exe gets the following error
    Exception EAccess Violation in module Illustrator_16_LS16.exe at 0001B836. Access violation at address 0041B836 in module Illustrator_16_LS16.exe read of address 00000008.
    Creative cloud doesn't list Illustrator 6 only try CC. Have tried that and I get the Error code 1 same as with CS6. All the other programs are there. There is no real link to just downlad CS6.
    Oct 23, 2013 11:47 AM   in reply to Conisus
    On the Creative Cloud page, once you select CS6, did you click on the 'Download'' button on the top right corner? Could you take a screenshot of what you are seeing?
    Alternatively, you can try this link: http://prodesigntools.com/adobe-cs6-direct-download-links.html
    Please read the Very Important Instruction before proceeding to download. Thanks!
    Oct 23, 2013 12:09 PM   in reply to amxyz
    Under creative cloud apps there is no CS6 to click on.
    Oct 23, 2013 7:36 PM   in reply to amxyz
    Yes, those should work for any CS6 app in English...  Here also are the CC direct download links if anyone needs a CC English version to quickly grab.
    Speculation is this odd glitch could be something on the Microsoft end, as they had some other problems with the Windows 8.1 update.
    Oct 24, 2013 9:39 AM   in reply to Alexei Humeniy
    Same problem here. Windows 8.0 with a fresh install, illustrator CC not working. Fortunatelly I had a full backup to restore. What's your problema Adobe? you have near 9.000 employees, and your software and bugs are going from bad to worse!!
    Hope you fire the responsable of this incredible problem! and please hire just responsable people!
1 2 Previous Next
Actions
