crankoide
Google Maps in Flex without Google Maps Flash API
Jul 1, 2013 12:03 AM
Tags: #flash #google #maps #api
Hello,
Does anyone know an alternative to embed Google Maps in a Flex application without Google Maps Flash API (because it is deprecated)?
To forgo Google Maps and use another map provider or to develop the application again with JavaScript/HTML are no options. Flex-IFrame or similar solutions (HTML iframe overlay) or a conversion to Adobe Air is not wanted.
Is there a solution available either commercial or open source to use the JavaScript SDK from Google in Flex (e.g. via ExternalInterface or Flex Ajax Bridge)? Or is there an alternative Flash SDK for Google Maps available?
Thanks!
    Jul 1, 2013 7:43 AM   in reply to crankoide
    Search the Apache Flex mailing list archives.  This discussion happened there a while a go.
    Aug 28, 2013 1:35 AM   in reply to crankoide
    Follow below stpes to integrate google map with flex application using javascript with wrapper.
    Step1: Add HTML div tag in wrapper
    Step2: Add below scripts into your wrapper (index.template.html)
    <script type="text/javascript" src="http://maps.googleapis.com/maps/api/js?key=AIzaSyDBe1ZFLWTfmXJ_tkBip77 koksIjY23gUU&sensor=false"></script>
    <div id="flashContent">
    Step3: Call methods from your flex application
    ExternalInterface.call("","mapArr")
    Step4:Add following method inot javascript file to load map with data
    Example:Codebase
                                                      Consumes lat/long information
                                                      function loadMap("{collect data}") {
                                                      //get the lat/long information for the address
        var mapOptions = {
        disableDefaultUI: true,
        zoom: 18,
        mapTypeId: google.maps.MapTypeId.ROADMAP
        locMap = new google.maps.Map(document.getElementById("{Id of 'div' added in wrapper ie index.template.html}"), mapOptions);
        codeAddress(mapArr);
                                                      function codeAddress(mapArr) {
        geocoder = new google.maps.Geocoder();
                                                      geocoder.geocode( { 'address': mapArr[0].address}, function(results, status) {
                                                      if (status == google.maps.GeocoderStatus.OK) {
                                                        locMap.setCenter(results[0].geometry.location);
                                                         addMarker(results[0].geometry.location, locMap, mapArr);
                                                       else {
        alert('Geocode was not successful for the following reason: ' + status);
                                                    document.getElementById("Id of 'div' added in wrapper ie index.template.html").style.display = 'block';
    Atul(9096448895)
    infoCepts technologies Pvt Ltd.
    Vot if Helpful
