Export sound from Flash CC
Jul 1, 2013 5:16 PM
For many years I've been using flash to generate animatics which I then import to After Effects to use as a base to build a project over.  The latest AE, however doesn't bring in sound with the SWF files, and the latest Flash doesn't export WAV (or any audio file).
I've managed to get some audio out by using export video - convert in media encoder, but the quality is terrible and completely out of sync with the original.
Is there some arcane method available that's not obvious?  Or has this functionality just been dropped from Flash?
    Jul 3, 2013 1:36 AM   in reply to Aerobotnik
    In Flash Pro CC, we have dropped support for the following formats (Windows AVI(*.avi), QuickTime(*.mov), WAV Audio(*.wav)) via Export > Export Movie.
    Can you share the source fla file and the exact steps which you followed to extract audio in Flash CC via AME. Since this issue is directly related to Adobe Media Encoder, we will try to reproduce this issue and escalate the issue to Adobe Media Encoder team.
    Sridhar Elangovan
    Jul 11, 2013 6:19 AM   in reply to Sridhar Elangovan
    I'm having a similar problem.  The "export video" function completely destroys the quality of the sound files embedded in my .fla document.  I have a voice professional recording, which in its raw format, sounds great.  After being processed through flash, it sounds like I'm talking in a bathtub, and there's a huge amount of crackling distortion.
    Has there been any further progress on Aerobotnik's original comments?
    Jul 12, 2013 3:38 AM   in reply to trasw
    We have tried exporting our Fla movie which have sound embedded in the timeline using Export > Export Movie. But while tried to play the exported sound, it does not have any crackling distortion sound. Since you are facing some problem in this case, please share the source fla file which you are facing this problem. Please provide the exact steps which will help us to reproduce the problem.
    Sridhar Elangovan
    Jul 16, 2013 3:12 AM   in reply to Aerobotnik
    Hi Adam,
    Thanks for sharing the file with the detailed notes. We are able to repdouce the issue with the file you have shared. We logged 2 internal bugs for the issues you reported above. Internal bug # 3595722 logged to track the difference in the output sound while export > export video. Internal bug # 3595727 logged to track the sound sync issue.
    Sridhar Elangovan
    Dec 24, 2013 9:20 AM   in reply to Sridhar Elangovan
    Sridhar, why do you no longer offer these export options? especially the audio export? i too have always used this to bring the audio into after effects when working on longer animations to correct sync issues and also cause i do additional special effects in AE. without this ability i too may need to look elsewhere for an animation program as this seriously hinders my workflow.
    i also don't understand for the export video why it does not go straight to the Media encoder and instead has to write a huge MOV file first...this seems convoluted at best. i am not an engineer so i am sure you have your reasons but maybe in the future get designers into the process when you guys make these changes and definitely before stripping key features out of programs
