MichaelDavidL
Problem rendering shadows with Firefox PDF plugin
Jul 2, 2013 8:11 AM
Tags: #pdf #export #cs6
When I add shadowing to pictures and text in InDesign and export to a PDF, the PDF reader in Firefox fails to render the shadows correctly. It renders them as black boxes rather than gradients. Here is a sample export of a photo that I shadowed in InDesign...
I've only found Firefox to be the problem. In the PDF readers I have this same PDF displays fine. The PDF reader for Chrome, and Internet Explorer display fine as well. Here's how the same PDF exported from InDesign appears with other browsers/readers...
ShadowedPictureInChrome.jpgI am posting a newsletter with shadowing to our website, so I would like the display of shadowing to work in all browsers. Any way to export the PDF from InDesign without displaying black boxes in Firefox?
If all else fails, I am thinking I may have to remove the shadowing from the PDF version of our newsletter... but I would really prefer to keep the shadowing. Any ideas/suggestions?
    Jul 2, 2013 8:19 AM   in reply to MichaelDavidL
    Firefoxes PDF viewer is pretty lousy
    Go to Tools>Options>Application and scroll down to Portable Document Format (PDF) and switch it to use Acrobat instead of Firefox PDF reader.
    And send those instructions out to your clients too.
    Jul 2, 2013 8:22 AM   in reply to MichaelDavidL
    I'd also suggest you get in touch with Mozilla themselves so they can release a fix for the problem. You can find twitter and facebook feeds as well as direct contact through their website.
    Jul 2, 2013 8:33 AM   in reply to MichaelDavidL
    However, (a last resort if all other things will fail), what you can try is to "simulate overprint" at output stage.
    This will flatten the whole thing.
    This option is available, if you output to EPS or PS (InDesign or AcrobatPro). Then you could redestill to PDF.
    Only recommended for a special purpose like yours.
    Uwe
    Jul 2, 2013 8:40 AM   in reply to Laubender
    Or just make a JPEG of it and put that up
  • Rob Day
    Oct 16, 2007
    Jul 2, 2013 12:14 PM   in reply to MichaelDavidL
    When you export force the PDF to flatten—set Compatability to Acrobat 4 (PDF 1.3).
    this flattened PDF works in my FF:
    http://www.zenodesign.com/forum/dsflat.pdf
    while the same page exported with live transparency does not, PDF/X-4 in this case:
    http://www.zenodesign.com/forum/dsx-4.pdf
    Jul 2, 2013 1:21 PM   in reply to Rob Day
    @Rob – flattening alone might not be enough in some cases. ;-)
    You have to make absolutely sure that there are no overprinting elements.
    Thus my recommendation: "Simulate Overprint" at output stage…
    Uwe
    Jul 2, 2013 1:41 PM   in reply to MichaelDavidL
    Is there a better workflow than this?
    @Michael – you could print to a PostScript* file (*.ps) out of InDesign (Composite-CMYK) and check "Simulate Overprint". Afterwards distill the PS file to PDF with Adobe Distiller that comes along with Adobe Acrobat Pro.
    * To be able to do this:
    On Mac OSX you need the "ADPDF9.PPD" file and you have to put it in a new folder named exactly "PPDs" (without quotation marks) in the "Presets" folder of your Adobe InDesign program folder (InDesign CS5, CS5.5 and CS6).
    Restart InDesign and go to the print dialog.
    Choose "PostScript File" for Printer.
    Choose "ADPDF9.PPD" for PPD.
    In the Output pane:
    For "Color" choose "Composite CMYK".
    Check "Simulate Overprint" in the lower region of the menu.
    All other settings should be self-explanatory…
    (like flattening transparency etc.)
    If not, ask here again.
    Uwe
  • Rob Day
    Oct 16, 2007
    Jul 2, 2013 2:25 PM   in reply to Laubender
    Just convert to RGB on export. So on this PDF'd page the orange (Patone spot) and black (CMYK) are set to overprint the cyan box (CMYK) with shadow. If I set the ID export output to this:
    I get this PDF which still is working in my FF:
    http://www.zenodesign.com/forum/rgb.pdf
    Jul 2, 2013 2:54 PM   in reply to Rob Day
    @Rob – ah, allright.
    And "Simulate Overprint" as option is also present in PDF Export (but of course [EDIT] not setting the export to PDF/X). You need that, too in case…
    Example:
    InDesign
    Exported to PDF with Comp sRGB. "Simulate Overprint" not checked in PDF Export:
    Exported to PDF with Comp sRGB. "Simulate Overprint" is checked in PDF Export:
    So, the best workflow for Michael would be Export PDF from InDesign with your settings plus "Simulate Overprint" checked.
    Uwe
    Message was edited by: Laubender Added the important word "not"!
