gchammer
How Do I use a variable for a datasource
Jul 2, 2013 11:23 AM
Tags: #adobe #livecycle #variable #datasource #data_connection
I'm trying to use a variable as a datasource so changes are easy to make with out having to look through the entire process.
If I use SLC_ENGFC_DEV_DS as the literal value the select statement it works. If I create a string variable and set the default value to the same thing I get the error
Exception: Invalid object name 'FLUDDEPT'.
    Jul 2, 2013 8:52 PM   in reply to gchammer
    Here is how I do this :
    Wasil
    Jul 3, 2013 9:54 PM   in reply to gchammer
    OK !
    I assume you are using sql server, use the query like this :
    select * from [database].[schema].[tablename];
    Make sure the user (mentioned in Jboss datasource has access(to the database) as well as the required permissions (select, delete etc) for the table object.
    e.g.
    Wasil
