mattgersting
SSL Problems with JRE 1.7
Jul 2, 2013 11:39 AM
Tags: #error #coldfusion #soap #coldfusion9 #ssl #cf9
Hello, all. Wondering if anyone else out there has encountered a similar issue:
I have several ColdFusion applications that speaking to another CF application via SOAP (CreateObject('webservice'...)), and that is happening over SSL. The certificate is valid, is not self-signed, and is not expired. This connection works fine on servers that are using the 1.6x JRE, but on servers using 1.7x the connection fails with the following error:
Unable to read WSDL from: {address}
Error: javax.net.ssll.SSLPeerUnverififedException: peer not authenticated.
If we downgrade the JRE on those servers with the error it goes away and connects fine.
Thoughts?
    Jul 2, 2013 3:24 PM   in reply to mattgersting
    Hi Matt, Perhaps the SSL is not in the Java 7 keystore but is in the Java 6 keystore. Use keytool to add SSL to Java 7 then while CF is configured to Java 7 restart CF and retest.
    EG:
    CMD prompt
    CD D:\Program Files\Java\1.7.0_nn\jre\bin>
    keytool -importcert -storepass changeit -noprompt -alias friendly_name -keystore ../lib/security/cacerts -trustcacerts -file d:\temp\certificate_file.cer
    HTH, Carl.
