php looping
Jul 2, 2013 11:15 PM
Using DW 5.5
I am trying to loop thru a DB table.  My connection to the DB works.  The table has multiple fields although I'm only trying to print 2 of them; the holder of the event and the event name in a vertical column with the holder above the event name.
Result I'm trying to get should look like this:
Holder
Event name
Holder
Event name
I get the desired results but only after a repitition of the 'if....{' and the $holder == ....holder'];' lines; it appears as follows:
if ($holder != $row_getEvents['event_holder']) { } $holder == $row_getEvents['event_holder']; if ($holder != $row_getEvents['event_holder']) { } $holder == $row_getEvents['event_holder']; if ($holder != $row_getEvents['event_holder']) { } $holder == $row_getEvents['event_holder'];
The above repeats ('if' thru 'if') for the total of the number of records in the table; then it echos the Holder and Event Name lines for all the records in the table as desired.
My recordset query is:  $query_getEvents = "SELECT * FROM event_schedule ORDER BY event_holder, event_date ASC";  (this obviously works because the data is there and presents in desired sequence); so, why doesn't the following produce only the data?
<body>
<h1>Manage Events</h1>
<table width="600">
<?php $holder = "holder is blank";   (I put 'holder is blank' here solely for testing, it will be null and the next line eliminated)
echo $holder; ?><br />
<?php do { ?>
  <tr align="center" valign="top">
        <td><?php echo $row_getEvents['event_holder'] . " / "; ?><br />
        </td></tr>
        <td><?php echo $row_getEvents['event_name'] . " / "; ?><br />
  </td></tr>
<?php } while ($row_getEvents = mysql_fetch_assoc($getEvents)); ?>
</table>
<p> </p>
</body>
</html>
<?php
mysql_free_result($getEvents);
Thanks in advance,
Tom Smith
    Jul 3, 2013 5:55 AM   in reply to TjmSmith
    <table width="600">
      <?php do { ?>
        <tr>
          <td><?php echo $row_getEvents['event_holder']; ?></td>
          <td><?php echo $row_getEvents['event_name']; ?></td>
        </tr>
    </table>
    Jul 3, 2013 6:21 PM   in reply to TjmSmith
    Try
    <?php $holder = null;
    do {
            $holder = $row_getEvents['event_holder'];
            echo $holder;
    <p>
    </p>
