pr_csc
Simple question relating to Cross Reference Formats
Jul 3, 2013 3:02 AM
Tags: #framemaker10 #paragraph
Sorry if this is a dim question, but I'm a FrameMaker novice and I'm not sure how to go about the following:
My document makes lots of use of cross-references and I've always created these with the source type as 'Paragraphs' and a format that uses <$paratext>
For example, a cross ref displayed as:
How do I perform task A?
takes the user to a pargraph titled:
I'd like to change this a bit by editing the text displayed in the link to be:
task A
but have it still take the user to same paragraph as before:
I just can't figure out a way to have different text displayed without having to set up a new format for every cross reference that I create (which can't be the right way to do it).
    Jul 3, 2013 4:09 AM   in reply to pr_csc
    See:
    How can I link to a marker (and display the marker content)?
    Basically, what you are asking for is that Cross Reference formats support a building block of:
    $markertext
    It's been on the FM wishlist forever.
    No sign it will appear in a release anytime soon.
    Jul 3, 2013 5:32 AM   in reply to pr_csc
    If the short form (Task A) is at the start or end of the paragraph/heading, you could use a run-in paragraph. A run-in is a true paragraph, except it remains on the same line as the first line of the paragraph that follows it, so the run-in blends smoothly into the follower. You need two paragraph paragraphs to simulate the heading - one is the run-in that begins the heading, one is a normal in-column paragraph for the remainder.
    For example:
    "How do I perform " is the run-in, and "task A?" is the normal.
    or:
    "Task A: " is the run-in, and "Getting rich beyone belief!" is the normal.
    You'd point the cross-reference to the normal paragraph that follows the run in.
    To include this two-paragraph heading in a TOC, you'd extract both paragraph formats that comprise it, and define a run-in and a normal format in the TOC, for each, to recreate a one-line appearance. The format for the run-in in the TOC would have no <$pagenum> building block.
    Search Google for terms like "FrameMaker run-in paragraph format" without quotes, for details.
    HTH
    Regards,
    Peter
    _______________________
    Peter Gold
    KnowHow ProServices
    task A
    Jul 3, 2013 6:10 AM   in reply to pr_csc
