drag-and-drop utility for Edge Animate(only x-axis)
Jul 3, 2013 4:16 AM
Tags: #edge_animate
KONBANWA from Japan.
I create the drag-and-drop utility for Edge Animate(only x-axis ). here.
http://ciruelo.jp/js/edge/dd/DandD.html
If you want to test.
1. copy all of code on DandD.html-stage-creationComplete to your edge file-stage-creationComplete.
2. use "draggableX()" method, like that.
//drag element "rect"
sym.$("rect").draggableX();
//drag element "dog", limited range
sym.$("dog").draggableX({minX:100,maxX:300});
//drag nested element "seekBarPointer", limited range
sym.$("seekBarPointer").draggableX({minX:0,maxX:160});
//drag element "pic" class, and scroll target element $("carouselBase"), click to rotate.
$(".pic").draggableX({
     target:sym.$("carouselBase"),
     onclick:function(e){
       $(e.target).css({
            "-moz-transform":"rotate(-45deg)",
          "-webkit-transform":"rotate(-45deg)",
          "-o-transform":"rotate(-45deg)",
          "-ms-transform":"rotate(-45deg)"
Maybe, moving on iPad
BTW, I want such a function on Edge Animate.
If I can be, without having to write a script.
Only use a panel like "Drag and Drop panel" ,  "Carousele panel" etc..
Thanks in advance. adobe team.
Ume.
    Oct 17, 2013 3:17 PM   in reply to YOSHIOKA Ume
    Thank you for this awesome ressource!
    You did such a great work - much appreciated.
    Cheers,
    Will
    Oct 17, 2013 4:28 PM   in reply to William Patin
    Nicely done!
    Oct 17, 2013 6:46 PM   in reply to YOSHIOKA Ume
    Very cool! Thanks for sharing!
    Sarah
    Oct 24, 2013 12:58 PM   in reply to YOSHIOKA Ume
    This is fantastic, and almost exactly what I was looking for.
    In the case of the carousel, suppose you wanted to have it loop in either direction? For example, when you get to the min or max X position, it would seemlessly start over?
    I'm trying to do a 360 panorama scene which would be great with this code!
    Oct 30, 2013 8:34 AM   in reply to YOSHIOKA Ume
    Ume,
    Thank you so much for this code! I am going to try it out in my project right now
Bookmarked By (1)
