Eyoyo
InDesign CC not working on my pc
Jul 3, 2013 9:47 AM
Tags: #indesign_cc #crashing_when_opening
It took me a while (install, reinstall etc...) to get my indesign files show properly after I installed the latest InDesign CC. However,  "InDesign stopped working" shows everytime I launched it.
I tried to sign out my Creative Cloud account and relaunch InDesign, and it is still not working. I saw someone posts about the fonts problem. I also found my fonts folder, but it seems that some problem fonts are protected by the system.
Anyone have other suggestions? Only InDesign has this issue.
    Jul 3, 2013 10:17 AM   in reply to Eyoyo
    Please try to perform the steps provided in the following article:
    http://helpx.adobe.com/indesign/kb/indesign-cc-crashing-launch.html
    Jul 3, 2013 11:35 AM   in reply to Eyoyo
    A slew of problematical fonts gets dumped into your Library/Fonts when you install the CC apps.
    On a Mac, run Disk Utility/Repair Disk Permissions immediately after installing any CC program.
    I am attaching an extract from the contents of my DU Log showing the fonts that needed repairs.
    If you don't require all of these fonts, I recommend that you immediately trash any unneeded Fonts in this list. (That will also shorten your Fonts Menu).
    I have a major problem with the way that Creative Cloud installs software:
    With CS, you were offered the option of installing fonts or not. In CC the whole Font Collection (including all these faulty ones!) get dumped onto our HDs whether we want them or not.
    That needs to change.
    Also: FAP 5 Plug-ins do not work with InD CC (and cause an immediate crash in Illustrator CC) so should be removed from both programs.
    Insider Software is working on an Upgrade.
    2013-06-25 02:01:02 -0400: Permissions differ on “Library/Fonts”; should be drwxrwxr-t ; they are drwxrwxr-x .
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/AmericanTypewriter.ttc”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Apple Chancery.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Apple LiGothic Medium.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Apple LiSung Light.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/AppleGothic.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/AppleMyungjo.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/AppleSDGothicNeo-ExtraBold.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/AppleSDGothicNeo-Heavy.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/AppleSDGothicNeo-Light.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/AppleSDGothicNeo-Medium.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/AppleSDGothicNeo-SemiBold.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/AppleSDGothicNeo-Thin.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/AppleSDGothicNeo-UltraLight.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Arial Black.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Arial Bold Italic.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Arial Bold.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Arial Italic.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Arial Narrow Bold Italic.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Arial Narrow Bold.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Arial Narrow Italic.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Arial Narrow.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Arial Rounded Bold.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Arial Unicode.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Arial.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/ArialHB.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/ArialHBBold.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Avenir Next Condensed.ttc”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Avenir Next.ttc”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Avenir.ttc”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Baskerville.ttc”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/BiauKai.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/BigCaslon.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Brush Script.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Chalkboard.ttc”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/ChalkboardSE.ttc”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Chalkduster.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/CharcoalCY.dfont”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Cochin.ttc”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Comic Sans MS Bold.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Comic Sans MS.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Copperplate.ttc”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Corsiva.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/CorsivaBold.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Courier New Bold Italic.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Courier New Bold.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Courier New Italic.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Courier New.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Damascus.ttc”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/DecoTypeNaskh.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Didot.ttc”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/EuphemiaCAS.ttc”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Futura.ttc”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/GenevaCY.dfont”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Georgia Bold Italic.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Georgia Bold.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Georgia Italic.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Georgia.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/GillSans.ttc”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/HeadlineA.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/HelveticaCY.dfont”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Herculanum.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Hiragino Sans GB W3.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Hiragino Sans GB W6.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Hoefler Text Ornaments.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Hoefler Text.ttc”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Impact.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/InaiMathi.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Kai.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Kailasa.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Kannada MN.ttc”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Kannada Sangam MN.ttc”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Kefa.ttc”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Khmer MN.ttc”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Khmer Sangam MN.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Marion.ttc”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Microsoft Sans Serif.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Optima.ttc”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/PTSans.ttc”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Palatino.ttc”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Papyrus.ttc”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/PlantagenetCherokee.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXGeneral.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXGeneralBol.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXGeneralBolIta.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXGeneralItalic.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXIntDBol.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXIntDReg.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXIntSmBol.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXIntSmReg.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXIntUpBol.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXIntUpDBol.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXIntUpDReg.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXIntUpReg.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXIntUpSmBol.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXIntUpSmReg.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXNonUni.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXNonUniBol.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXNonUniBolIta.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXNonUniIta.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXSizFiveSymReg.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXSizFourSymBol.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXSizFourSymReg.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXSizOneSymBol.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXSizOneSymReg.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXSizThreeSymBol.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXSizThreeSymReg.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXSizTwoSymBol.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXSizTwoSymReg.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXVar.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/STIXVarBol.otf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Skia.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Tahoma Bold.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Tahoma.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Times New Roman Bold Italic.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Times New Roman Bold.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Times New Roman Italic.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Times New Roman.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Trebuchet MS Bold Italic.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Trebuchet MS Bold.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Trebuchet MS Italic.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Trebuchet MS.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Verdana Bold Italic.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Verdana Bold.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Verdana Italic.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Verdana.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Webdings.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Wingdings 2.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Wingdings 3.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Wingdings.ttf”
    2013-06-25 02:01:02 -0400: Repaired “Library/Fonts/Zapfino.ttf”
    2013-06-25 02:02:40 -0400: Permissions repair complete
    Jul 4, 2013 11:17 AM   in reply to CameraAnn
    Moving this discussion to the InDesign forum.
    Jul 4, 2013 11:31 AM   in reply to CameraAnn
    Ann, no doubt you've found some font issues here, but as I read though the log not one of the fonts in that list appears to be a font from Adobe....
    Jul 5, 2013 12:04 PM   in reply to Peter Spier
    Other possible sources of these fonts may have been new installations of MS Office, FontAgent Pro 5 (+ some 650 Google fonts which came with FAP5) and an update to Mac OSX 10.8.4 all of which I did during the same period around the time that Creative Cloud went live on 17th June?
    I notice that the list that I posted here was actually a later Log file, from after I had already removed a large number of Asian and ME fonts which had been flagged by Disk Utility previously, and which I am fairly certain were Adobe CC installations?
    This was the earlier (6/22/2013) DU Report:
    Repairing permissions for “Roaring Lion”
    Group differs on “Library”; should be 0; group is 80.
    Permissions differ on “Library”; should be drwxr-xr-x ; they are drwxrwxr-x .
    Repaired “Library”
    ACL found but not expected on “Library/Application Support/Apple/Remote Desktop”
    Repaired “Library/Application Support/Apple/Remote Desktop”
    ACL found but not expected on “Library/Application Support/Apple/Remote Desktop/Notify”
    Repaired “Library/Application Support/Apple/Remote Desktop/Notify”
    Group differs on “Library/Fonts/AlBayan.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/AlBayan.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/AlBayan.ttf”
    Group differs on “Library/Fonts/AlBayanBold.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/AlBayanBold.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/AlBayanBold.ttf”
    Group differs on “Library/Fonts/AmericanTypewriter.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/AmericanTypewriter.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Andale Mono.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Andale Mono.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/Andale Mono.ttf”
    Group differs on “Library/Fonts/Apple Chancery.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Apple Chancery.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Apple LiGothic Medium.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Apple LiGothic Medium.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Apple LiSung Light.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Apple LiSung Light.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/AppleGothic.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/AppleGothic.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/AppleMyungjo.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/AppleMyungjo.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/AppleSDGothicNeo-ExtraBold.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/AppleSDGothicNeo-ExtraBold.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/AppleSDGothicNeo-Heavy.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/AppleSDGothicNeo-Heavy.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/AppleSDGothicNeo-Light.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/AppleSDGothicNeo-Light.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/AppleSDGothicNeo-Medium.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/AppleSDGothicNeo-Medium.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/AppleSDGothicNeo-SemiBold.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/AppleSDGothicNeo-SemiBold.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/AppleSDGothicNeo-Thin.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/AppleSDGothicNeo-Thin.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/AppleSDGothicNeo-UltraLight.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/AppleSDGothicNeo-UltraLight.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Arial Black.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Arial Black.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Arial Bold Italic.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Arial Bold Italic.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Arial Bold.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Arial Bold.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Arial Italic.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Arial Italic.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Arial Narrow Bold Italic.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Arial Narrow Bold Italic.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Arial Narrow Bold.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Arial Narrow Bold.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Arial Narrow Italic.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Arial Narrow Italic.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Arial Narrow.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Arial Narrow.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Arial Rounded Bold.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Arial Rounded Bold.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Arial Unicode.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Arial Unicode.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Arial.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Arial.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/ArialHB.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/ArialHB.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/ArialHBBold.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/ArialHBBold.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Avenir Next Condensed.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Avenir Next Condensed.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Avenir Next.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Avenir Next.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Avenir.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Avenir.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Ayuthaya.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Ayuthaya.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/Ayuthaya.ttf”
    Group differs on “Library/Fonts/Baghdad.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Baghdad.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/Baghdad.ttf”
    Group differs on “Library/Fonts/Bangla MN.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Bangla MN.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/Bangla MN.ttc”
    Group differs on “Library/Fonts/Bangla Sangam MN.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Bangla Sangam MN.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/Bangla Sangam MN.ttc”
    Group differs on “Library/Fonts/Baskerville.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Baskerville.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/BiauKai.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/BiauKai.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/BigCaslon.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/BigCaslon.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Brush Script.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Brush Script.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Chalkboard.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Chalkboard.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/ChalkboardSE.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/ChalkboardSE.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Chalkduster.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Chalkduster.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/CharcoalCY.dfont”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/CharcoalCY.dfont”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Cochin.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Cochin.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Comic Sans MS Bold.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Comic Sans MS Bold.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Comic Sans MS.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Comic Sans MS.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Copperplate.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Copperplate.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Corsiva.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Corsiva.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/CorsivaBold.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/CorsivaBold.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Courier New Bold Italic.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Courier New Bold Italic.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Courier New Bold.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Courier New Bold.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Courier New Italic.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Courier New Italic.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Courier New.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Courier New.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Damascus.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Damascus.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/DecoTypeNaskh.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/DecoTypeNaskh.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Devanagari Sangam MN.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Devanagari Sangam MN.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/Devanagari Sangam MN.ttc”
    Group differs on “Library/Fonts/DevanagariMT.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/DevanagariMT.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/DevanagariMT.ttf”
    Group differs on “Library/Fonts/DevanagariMTBold.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/DevanagariMTBold.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/DevanagariMTBold.ttf”
    Group differs on “Library/Fonts/Didot.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Didot.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/EuphemiaCAS.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/EuphemiaCAS.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Futura.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Futura.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/GenevaCY.dfont”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/GenevaCY.dfont”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Georgia Bold Italic.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Georgia Bold Italic.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Georgia Bold.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Georgia Bold.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Georgia Italic.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Georgia Italic.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Georgia.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Georgia.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/GillSans.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/GillSans.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Gujarati Sangam MN.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Gujarati Sangam MN.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/Gujarati Sangam MN.ttc”
    Group differs on “Library/Fonts/GujaratiMT.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/GujaratiMT.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/GujaratiMT.ttf”
    Group differs on “Library/Fonts/GujaratiMTBold.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/GujaratiMTBold.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/GujaratiMTBold.ttf”
    Group differs on “Library/Fonts/Gungseouche.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Gungseouche.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/Gungseouche.ttf”
    Group differs on “Library/Fonts/Gurmukhi MN.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Gurmukhi MN.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/Gurmukhi MN.ttc”
    Group differs on “Library/Fonts/Gurmukhi Sangam MN.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Gurmukhi Sangam MN.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/Gurmukhi Sangam MN.ttc”
    Group differs on “Library/Fonts/Gurmukhi.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Gurmukhi.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/Gurmukhi.ttf”
    Group differs on “Library/Fonts/HeadlineA.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/HeadlineA.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Hei.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Hei.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/Hei.ttf”
    Group differs on “Library/Fonts/HelveticaCY.dfont”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/HelveticaCY.dfont”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Herculanum.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Herculanum.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Hiragino Sans GB W3.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Hiragino Sans GB W3.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Hiragino Sans GB W6.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Hiragino Sans GB W6.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Hoefler Text Ornaments.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Hoefler Text Ornaments.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Hoefler Text.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Hoefler Text.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Impact.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Impact.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/InaiMathi.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/InaiMathi.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Kai.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Kai.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Kailasa.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Kailasa.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Kannada MN.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Kannada MN.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Kannada Sangam MN.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Kannada Sangam MN.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Kefa.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Kefa.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Khmer MN.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Khmer MN.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Khmer Sangam MN.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Khmer Sangam MN.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Marion.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Marion.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Microsoft Sans Serif.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Microsoft Sans Serif.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/MshtakanBold.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/MshtakanBold.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/MshtakanBold.ttf”
    Group differs on “Library/Fonts/MshtakanBoldOblique.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/MshtakanBoldOblique.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/MshtakanBoldOblique.ttf”
    Group differs on “Library/Fonts/MshtakanOblique.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/MshtakanOblique.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/MshtakanOblique.ttf”
    Group differs on “Library/Fonts/MshtakanRegular.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/MshtakanRegular.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/MshtakanRegular.ttf”
    Group differs on “Library/Fonts/Myanmar MN.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Myanmar MN.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/Myanmar MN.ttc”
    Group differs on “Library/Fonts/Myanmar Sangam MN.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Myanmar Sangam MN.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/Myanmar Sangam MN.ttf”
    Group differs on “Library/Fonts/NISC18030.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/NISC18030.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/NISC18030.ttf”
    Group differs on “Library/Fonts/NanumGothic.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/NanumGothic.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/NanumGothic.ttc”
    Group differs on “Library/Fonts/NanumMyeongjo.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/NanumMyeongjo.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/NanumMyeongjo.ttc”
    Group differs on “Library/Fonts/NanumScript.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/NanumScript.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/NanumScript.ttc”
    Group differs on “Library/Fonts/NewPeninimMT.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/NewPeninimMT.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/NewPeninimMT.ttf”
    Group differs on “Library/Fonts/NewPeninimMTBold.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/NewPeninimMTBold.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/NewPeninimMTBold.ttf”
    Group differs on “Library/Fonts/NewPeninimMTBoldInclined.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/NewPeninimMTBoldInclined.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/NewPeninimMTBoldInclined.ttf”
    Group differs on “Library/Fonts/NewPeninimMTInclined.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/NewPeninimMTInclined.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/NewPeninimMTInclined.ttf”
    Group differs on “Library/Fonts/Optima.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Optima.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Oriya MN.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Oriya MN.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/Oriya MN.ttc”
    Group differs on “Library/Fonts/Oriya Sangam MN.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Oriya Sangam MN.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/Oriya Sangam MN.ttc”
    Group differs on “Library/Fonts/Osaka.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Osaka.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/Osaka.ttf”
    Group differs on “Library/Fonts/OsakaMono.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/OsakaMono.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/OsakaMono.ttf”
    Group differs on “Library/Fonts/PCmyoungjo.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/PCmyoungjo.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/PCmyoungjo.ttf”
    Group differs on “Library/Fonts/PTSans.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/PTSans.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Palatino.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Palatino.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Papyrus.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Papyrus.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Pilgiche.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Pilgiche.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/Pilgiche.ttf”
    Group differs on “Library/Fonts/PlantagenetCherokee.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/PlantagenetCherokee.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXGeneral.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXGeneral.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXGeneralBol.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXGeneralBol.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXGeneralBolIta.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXGeneralBolIta.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXGeneralItalic.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXGeneralItalic.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXIntDBol.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXIntDBol.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXIntDReg.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXIntDReg.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXIntSmBol.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXIntSmBol.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXIntSmReg.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXIntSmReg.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXIntUpBol.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXIntUpBol.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXIntUpDBol.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXIntUpDBol.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXIntUpDReg.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXIntUpDReg.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXIntUpReg.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXIntUpReg.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXIntUpSmBol.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXIntUpSmBol.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXIntUpSmReg.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXIntUpSmReg.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXNonUni.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXNonUni.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXNonUniBol.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXNonUniBol.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXNonUniBolIta.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXNonUniBolIta.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXNonUniIta.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXNonUniIta.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXSizFiveSymReg.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXSizFiveSymReg.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXSizFourSymBol.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXSizFourSymBol.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXSizFourSymReg.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXSizFourSymReg.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXSizOneSymBol.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXSizOneSymBol.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXSizOneSymReg.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXSizOneSymReg.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXSizThreeSymBol.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXSizThreeSymBol.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXSizThreeSymReg.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXSizThreeSymReg.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXSizTwoSymBol.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXSizTwoSymBol.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXSizTwoSymReg.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXSizTwoSymReg.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXVar.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXVar.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/STIXVarBol.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/STIXVarBol.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Sathu.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Sathu.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/Sathu.ttf”
    Group differs on “Library/Fonts/Silom.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Silom.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/Silom.ttf”
    Group differs on “Library/Fonts/Sinhala MN.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Sinhala MN.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/Sinhala MN.ttc”
    Group differs on “Library/Fonts/Sinhala Sangam MN.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Sinhala Sangam MN.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/Sinhala Sangam MN.ttc”
    Group differs on “Library/Fonts/Skia.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Skia.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Tahoma Bold.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Tahoma Bold.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Tahoma.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Tahoma.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Times New Roman Bold Italic.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Times New Roman Bold Italic.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Times New Roman Bold.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Times New Roman Bold.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Times New Roman Italic.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Times New Roman Italic.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Times New Roman.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Times New Roman.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Trebuchet MS Bold Italic.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Trebuchet MS Bold Italic.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Trebuchet MS Bold.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Trebuchet MS Bold.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Trebuchet MS Italic.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Trebuchet MS Italic.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Trebuchet MS.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Trebuchet MS.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Verdana Bold Italic.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Verdana Bold Italic.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Verdana Bold.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Verdana Bold.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Verdana Italic.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Verdana Italic.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Verdana.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Verdana.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Webdings.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Webdings.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Wingdings 2.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Wingdings 2.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Wingdings 3.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Wingdings 3.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Wingdings.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Wingdings.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/Zapfino.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/Zapfino.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Group differs on “Library/Fonts/ヒラギノ丸ゴ Pro W4.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/ヒラギノ丸ゴ Pro W4.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/ヒラギノ丸ゴ Pro W4.otf”
    Group differs on “Library/Fonts/ヒラギノ丸ゴ ProN W4.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/ヒラギノ丸ゴ ProN W4.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/ヒラギノ丸ゴ ProN W4.otf”
    Group differs on “Library/Fonts/ヒラギノ明朝 Pro W3.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/ヒラギノ明朝 Pro W3.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/ヒラギノ明朝 Pro W3.otf”
    Group differs on “Library/Fonts/ヒラギノ明朝 Pro W6.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/ヒラギノ明朝 Pro W6.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/ヒラギノ明朝 Pro W6.otf”
    Group differs on “Library/Fonts/ヒラギノ⾓角ゴ Pro W3.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/ヒラギノ⾓角ゴ Pro W3.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/ヒラギノ⾓角ゴ Pro W3.otf”
    Group differs on “Library/Fonts/ヒラギノ⾓角ゴ Pro W6.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/ヒラギノ⾓角ゴ Pro W6.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/ヒラギノ⾓角ゴ Pro W6.otf”
    Group differs on “Library/Fonts/ヒラギノ⾓角ゴ Std W8.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/ヒラギノ⾓角ゴ Std W8.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/ヒラギノ⾓角ゴ Std W8.otf”
    Group differs on “Library/Fonts/ヒラギノ⾓角ゴ StdN W8.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/ヒラギノ⾓角ゴ StdN W8.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/ヒラギノ⾓角ゴ StdN W8.otf”
    Group differs on “Library/Fonts/儷宋 Pro.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/儷宋 Pro.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/儷宋 Pro.ttf”
    Group differs on “Library/Fonts/儷黑 Pro.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/儷黑 Pro.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/儷黑 Pro.ttf”
    Group differs on “Library/Fonts/华⽂文仿宋.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/华⽂文仿宋.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/华⽂文仿宋.ttf”
    Group differs on “Library/Fonts/华⽂文细⿊黑.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/华⽂文细⿊黑.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/华⽂文细⿊黑.ttf”
    Group differs on “Library/Fonts/华⽂文⿊黑体.ttf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/华⽂文⿊黑体.ttf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/华⽂文⿊黑体.ttf”
    Group differs on “Library/Fonts/宋体.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/宋体.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/宋体.ttc”
    Group differs on “Library/Fonts/楷体.ttc”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/楷体.ttc”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/楷体.ttc”
    Group differs on “Library/Fonts/雅痞-简.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/雅痞-简.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/雅痞-简.otf”
    Group differs on “Library/Fonts/雅痞-繁.otf”; should be 0; group is 80.
    Permissions differ on “Library/Fonts/雅痞-繁.otf”; should be -rw-r--r-- ; they are -rw-rw-r-- .
    Repaired “Library/Fonts/雅痞-繁.otf”
    Group differs on “Library/Preferences/com.apple.alf.plist”; should be 80; group is 0.
    Repaired “Library/Preferences/com.apple.alf.plist”
    Permissions differ on “usr/lib/ruby”; should be lrwxr-xr-x ; they are drwxr-xr-x .
    Repaired “usr/lib/ruby”
    I have had no further font problems after I removed most of these fonts but am having to use FontBook for the moment until FAP posts some new plug-ins.
    Jul 5, 2013 1:29 PM   in reply to CameraAnn
    Again, none of those fonts are from Adobe, but I wouldn't be surprised if the Asian faces with the Asian characters in the names casued problems in cc. See http://forums.adobe.com/message/5457536#5457536
    and please, if you want to post log files inthe future, put them on pastebin.com and put links here. Thanks.
    Jul 5, 2013 6:39 PM   in reply to Peter Spier
    Sorry about that!
    I had wanted to add a PDF as an attachment (but it seems that you can't do that here?) and had never heard of pastebin.com until now -- but I will now know for next time.
