khelmore
Are there any issues having Audition 3 AND 6 installed on the same machine?
Jul 3, 2013 6:27 PM
Tags: #audition #cs6 #cs3.0
I work at a radio station and I want us to upgrade to Audition CS6, however our engineers believe there are bugs with having both versions installed.
I want to have both because of the backwards compatability issue (6 wont open sessions created with 3). They say that there are definitely issues with this.
Can anybody explain them to me?
    Jul 3, 2013 7:03 PM   in reply to khelmore
    Shouldn't be any problem having both installed at the same time. May be some weirdness with playback or recording if both are running at the same time, depending on the driver and audio device, but nothing that can't be handled.
    If they can share what bugs they believe will cause problems, I can look into it further.
    Jul 3, 2013 7:08 PM   in reply to khelmore
    I have both versions on the same Windows computer. And they work fine.
    There is coversion tool from ses to sesx.
    Jul 4, 2013 1:41 AM   in reply to khelmore
    By 'engineers' I'm assuming they are train drivers and hence can be forgiven for not knowing that all versions of Audition (and even CEP) can all live happily on the same machine.
    Audition 3 was the last version to open an ses file. Later versions of Audition will open a Audition v3 xml but without fx
    The tool you need to do the conversion is http://www.aatranslator.com.au/ses2sesx.html (I think it's still available)
    If you find it useful consider making a donation
    If you need to convert from sesx to ses then you will need www.aatranslator.com.au but it doesn't convert fx
  • SteveG(AudioMasters)
    Oct 26, 2006
    Jul 4, 2013 2:13 AM   in reply to khelmore
    I should get some new 'engineers' - preferably ones who know things as a result of sensible investigations, rather than guessing believing them to be the case.
    The simple fact of the matter is that all versions of Audition that are supported by any given OS can exist on a machine, quite happily, at the same time.
