Narmine700
Making a technical drawing using a handmade drawing
Jul 4, 2013 9:15 AM
Tags: #illustrator #drawing #technical
I have to make a technical drawing using a handmade drawing. When I use technical drawing option, I get a technical drawing with double lines, bacause the lines of my original drawings are a little thick. How can I get a tecnical drawing with one line and not double lines?
    Jul 4, 2013 9:19 AM   in reply to Narmine700
    Don't use Autotrace features.
    Jul 4, 2013 9:41 AM   in reply to Narmine700
    Narmine,
    Presumably, the drawing should have simple paths/segments (straight/circular/elliptic/whatever), and you may make certain changes if the hand drawn artwork is a sketch/draft.
    You may use the Pen Tool, Tools in the Rectangle Tool group, and other functions, using the present drawing as a template (you  may lock it and work on top of it).
    More details may give more details.
    And what Monika said.
    Jul 4, 2013 11:29 PM   in reply to Narmine700
    As Monika said - if it's supposed to be a "technical drawing" you can't use auto-trace. The whole point of drawing with exact measurements would be lost...
    Mylenium
    Jul 5, 2013 1:06 AM   in reply to Narmine700
    I see. in that case you may have better luck scanning it and mangling it in Photoshop. Eroding and smoothing lines based on the relevant selection tools there might prove useful and often works if you want to simulate a slightly scratchy "historic" look. For anything else cleanly re-drawing/ manualyl tracing in AI might be more efficient.
    Mylenium
    Jul 5, 2013 9:23 AM   in reply to Narmine700
    The FIRST thing you need to do is state what version of Illustrator you are using. No less than seven different versions are frequently referenced in this forum and the autotrace feature was rebuilt in CS6.
    If by "technical drawing" you're just refering to the name of one of the presets of the autotrace feature, and if you insist on using autotracing, then you need to read up on and experiment with the autotrace settings. Basically, you need to be autotracing in centerline mode, not outline mode. Turn on Stroke, turn off Fills. Probably turn on Ignore White. Max out the Maximum Stroke Weight.
    But again, specific settings may differ depending on what version you're using.
    JET
