Dreamweaver CC Background
Jul 4, 2013 5:15 PM
I have just changed to Dreamweaver CC and the design page background is black. In Dreamweaver 5.5 it is white. How do I change that,
Many Thanks,
Robin Chapple
    Jul 4, 2013 5:25 PM   in reply to yallambie3085
    Edit --> Preferences will show the following dialog
    Jul 4, 2013 7:10 PM   in reply to yallambie3085
    Sorry to be the bearer of bad news, you have not installed the default version of DWCC.
    Uninstall DW, using the procedure here. Reinstall directly from Adobe Creative Cloud.
    Jul 5, 2013 3:37 AM   in reply to yallambie3085
    Hi yallambie3085,
    Please try the steps mentioned below.
    1. Sign out and then sign in again in the Creative Cloud app.
    2. To sign out, click the gear icon and then Choose Preferences >  General > Account; and then click Sign Out from Creative Cloud.
    3. Restart your computer.
    4. Launch Creative Cloud app again and Sign In.
    5. You should see an Install link next to Dreamweaver now
    Bhawna
    Jul 6, 2013 1:31 PM   in reply to yallambie3085
    @Yallambie,
    background:transparent  has been known to cause this in CS6 and CC.  Remove transparent from your CSS code and it should be just fine in Design View.
    Nancy O.
    Jul 6, 2013 2:50 PM   in reply to yallambie3085
    White is not valid CSS.  Also the default font style is normal.  You don't need to express what is already there by default.  It just clutters your files with unnecessary code.
    Try this instead of what you have now.  Save.
    body {
              font-family:  Verdana, Arial, Helvetica, sans-serif;
              font-size: 16px;
              background: #FFF;
              margin:0;
    Nancy O.
    Jul 6, 2013 3:36 PM   in reply to yallambie3085
    Can we see a link to your site?  I suspect other code errors are coming into play here.
    Nancy O.
    Jul 6, 2013 5:47 PM   in reply to yallambie3085
    CC requires much stricter adherence to web standards than ever before.
    On that one page, you have 44 HTML errors that need to be fixed. Some are very serious error that can cripple your site in modern browsers.
    http://validator.w3.org/check?verbose=1&uri=http%3A%2F%2Fwww.rotary979 0.org.au%2F4a%2Fcomm%2Findex.asp
    You have about 23 CSS errors (excluding the Yahoo UI code) that need attention.
    http://jigsaw.w3.org/css-validator/validator?profile=css21&warning=0&u ri=http%3A%2F%2Fwww.rotary9790.org.au%2F4a%2Fcomm%2Findex.asp
    In summary, this site could really benefit from a total rebuild.
    In the meantime, use the code validation tools below to check your code regularly  and fix reported errors before they become a problem.
    CSS - http://jigsaw.w3.org/css-validator/
    HTML - http://validator.w3.org/
    In Design View, disable CSS.  Go to View > Style Rendering > untick Display Styles.
    Good Luck!
    Nancy O.
    Jul 7, 2013 5:22 AM   in reply to yallambie3085
    DW does prepare proper code. But users will often direct DW to do improper things, especially if they edit pages directly in the code.
