leopard1063
试用adobe CC的问题反馈
Jul 4, 2013 7:50 PM
adobe的的技术们,你们好!很高兴能在这个炎热的夏天试用到adobe cc。在试用aodbe cc过程中感觉adobe cc是个让人兴奋而富有新奇力量的软件,但在试用中也发现有不少bug,现在将问题反馈过来,请技术及时修正。
问题一:photoshop字符面板“所选字符字距调整”向左拖或向右拖数值会反弹回去。
问题二:photoshop描边,向外描边的角能否修改为直角,或圆角和直角为可选。
问题三:photoshop智能图层,在设计中经常会将图层转变成智能图层,同时对其智能图层进行放大或缩小,但是会出现缩小或放大时失效的情况,例 如缩小后,确定,刚才明明缩小的图片会马上就反弹回去,变成缩小前的尺寸。
问题四:indesign对字体支持问题,有些字体id不支持会出现启动闪退的现象。
暂时发现这么多。希望改进。。。我会陆续进行反馈的!
  • Trevor Dennis
    May 24, 2010
    Jul 4, 2013 10:19 PM   in reply to leopard1063
    leopard1063 wrote:
    The technique, how are you! Very pleased in this hot summer trial to adobe cc. In the course of the trial aodbe cc feeling adobe cc is exciting and full of new strength of the software, but in the trial also found that there are many bug, feedback over the problem now, please timely correction technology.
    Question one: photoshop Character Panel "selected character kerning" drag left or right values ​​will bounce back.
    Problem two: photoshop stroke, stroke angle outward at right angles can modify or rounded corners and right angles are optional.
    Question three: photoshop Smart Object layer in the design will often layers into smart layers, while its smart layers to zoom in or out, but it will appear when you zoom in or failure, for example, after narrowing to identify, just obviously reduced picture will immediately bounce back into pre-reduced size.
    Question four: indesign right font support issues, some font id does not appear to support start-flash back phenomenon.
    Blimey, that Google Translate is good!
    Q1) Yes, that is a known problem, and will no doubt be addressed shortly.
    Q1)是的,这是一个已知的问题,毫无疑问会在短期内解决。
    Q2)  See this thread: http://forums.adobe.com/thread/1247799?tstart=0
    Q2)主题:
    Q3)  Hmmm...  Can anyone make sense of this one?
    Q3)嗯......任何人都可以做这个意识?
    Q4)  Will this be an Asian font issue?  http://help.adobe.com/en_US/photoshop/cs/using/WSfd1234e1c4b69f30ea53e 41001031ab64-7580a.html
    Q4)这是一个亚洲的字体问题?
    Jul 10, 2013 11:28 PM   in reply to Trevor Dennis
    The question 3 is:
    Photoshop smart object: We usually convert layers to smart objects, and then scale the smart object. Sometimes the scale failed, I selected the smart object, reduced it to a smaller size, press OK. The smart object first reduced and then bounced back to the original size.
