Resolution seems a little low on big screen TV
Jul 5, 2013 1:53 PM
I shot some video at 1920x1080 (30 frames per sec). I used continuous lighting to light my subject. ISO was 640. The final results look really good. However, after burning to DVD using Encore to prepare the DVD, the movie looks a bit pixely. It does not appear noisy at all (because of the 640 iso), just a bit mid resolution. I have seen sharper, higher quality video on my big screen tv when I view a movie or TV. My big scrren TV is 50"
Is this normal or have I exported the movie improperly from Premiere to get this issue? The export settings I used from Premiere were: Format:Quicktime, Preset:HD1080i 29.97, H.264, 48khz
Thank you.
    Jul 5, 2013 3:03 PM   in reply to whitby rider
    Just to make sure that we are addressing the same problem, are you saying that you shot HD, then output to an SD DVD-Video, and are judging its resolution/quality vs the HD original material, or something else? The more info, the better, please.
    Jul 5, 2013 3:38 PM   in reply to whitby rider
    Comparison picture of video screen sizes http://forums.adobe.com/thread/1120039
    A DVD screen is a LOT smaller than a HiDef screen... so when you put a DVD screen on a HiDef TV, the "expanded" image will not be as good as a true HiDef file
    Jul 5, 2013 3:53 PM   in reply to whitby rider
    Sorry, but if you use DVD for your Encore project, the encoder within Encore will automatically re-compress and downconvert your H.264 HD video content to MPEG-2 SD. You cannot override this at all. The only way to author an Encore project in HD would be to open a new Blu-ray project.
    By the way, you will need a third-party burning software to write to DVD since Encore itself will not allow you to burn HD material at all to DVD (HD content can only be written to BD-R/RE in Encore). Write to a Blu-ray folder, then use the third-party software for the final burn. You will also need a Blu-ray player that can read AVCHD discs in order to use HD burned to DVD.
    Here are the restrictions for HD files that are to be burned onto DVD:
    1) The total bitrate (including video, audio, motion menus and miscellaneous content) must not exceed 18 Mbps combined.
    2) Audio should be a separate file (unmuxed), and be exported as Dolby Digital (AC-3). Do not mux (interleave) video and audio together as a single file: This will force Encore to re-compress both video and audio.
    Jul 5, 2013 6:31 PM   in reply to whitby rider
    If you wish to come very close to maintaining the resolution and quality of your HD footage, you can Burn to BD (Blu-ray Disc) from Encore. It still figures into the mix. That will show the client what you have done, in a very good light.
    This graphic, of the differences betwen some common Frame Sizes, might give you an idea of DVD-Video, which will be SD (Standard Def), vs HD (High Def), and then some larger frame sizes:
    Notice DVD vs the two most popular HD resolutions. That is what you are fighting right now.
    Good luck, and hope that helps.
    Jul 5, 2013 6:51 PM   in reply to whitby rider
    To burn a BD (Blu-ray Disc), you DO need a BD burner, and BD blank media.
    As for the Mac "super drive," I am a 100% PC person, so cannot help.
    Now, with a short Duration Project (about 20 mins.), one CAN burn an HD Project to a DVD-Video disc, but will need to use a BD burner, and play that on a BD player, as it is really not a DVD-Video, but a hybrid, or sorts.
    Good luck, and maybe others can address "super drive."
    Jul 5, 2013 6:59 PM   in reply to whitby rider
    This forum is blessed with a lot of Mac-folk, and they can be so very helpful.
    As it's into the July 4th holiday in the US, you might need to wait a bit, for them to come back to the forums, and help you out there.
    Also, most of Adobe USA is on a one-week holiday, so they will not be back into their offices, until July 8th.
    Jul 5, 2013 11:53 PM   in reply to whitby rider
    When I make a DVD from HD material, I export my timeline using a High quality "lossleess" codec, e.g. the free download UT codec.  This produces a very large file, but avoids a lot of problems with quality in the necessary re-encoding.
    I then use AME to produce a DVD legal file for Encore.  I create my DVD, and then I play it on a player which has Up-scaling on my Hi-def TV.  Up-scaling players give much better results with DVDs than straight DVD players when you have a large screen TV.
    The cameras you use make it sound as though you may be coming from a still photograph background.  Well all the problems caused by lack of pixels and down-scaling you met there are present in video, but in spades!!!
    The frame for 1920x1080 HD video has around 2 megapixels, while the frame for PAL SD video has round 0.4 megapixels.  Think how many megapixels you would want in a still image to print at A4 size with adequate results, let alone a poster sized 40 inch sheet of paper.  NTSC video has even fewer pixels than PAL!
    Jul 6, 2013 2:58 AM   in reply to Alan Craven
    Do you scale it down or leave it 1920x1080.
    Jul 6, 2013 3:33 AM   in reply to Ann Bens
    Check my second paragraph!
    I find that I can get even higher quality by using Vdub, with the Lanczos filter to do the actual down-scaling of the "lossless" export, but that seemed over-kill in the present thread.
    Jul 6, 2013 5:11 AM   in reply to Alan Craven
    It does not say when you are scaling down when making the avi or the mpeg-2dvd.
    Premiere also uses lanczos.
    Jul 6, 2013 7:49 PM   in reply to whitby rider
    That is most likely because you have an upscaling DVD player
    Plus, yes, a movie studio will use encoding software that costs $20K or more
    Jul 7, 2013 10:08 AM   in reply to John T Smith
    And they compress almost frame by frame to get the best compression possible.
    Not something the rest of us can really match.
    Jul 7, 2013 2:30 PM   in reply to whitby rider
    how come a DVD movie looks hi-def on my 50" screen?
    It doesn't.  Watch the same movie on Blu-ray and you'll see the difference.
    Jul 7, 2013 2:41 PM   in reply to whitby rider
    Well, given the difference in resources and source material, this is not surprising.
