Batch JPG to 72 DPI
Aug 28, 2006 6:33 PM
I have read through threads on changing dpi through batch process, but I can not find answer I am looking for. I have about 200 images I have to convert to 72dpi 1024x768 JPG's from TIF's. I understand that the resolution of 72dpi is not necessary for web browsing, but since it is a requirement for the images I have to submit, I have no choice but to change dpi to 72. Can I do it through Fireworks? I see nowhere to change dpi, only size.
    Aug 29, 2006 6:46 AM   in reply to feefriend
    Open one of the images in Fireworks and change its resolution to 72 PPI
    [Modify > canvas > Image size. Change the resolution to 72 PPI. Click OK
    to accept the changes and close the dialog box.
    Open the History panel and click on the "Image Size" step to select it.
    Open the history panel options menu and select save as command.
    Give the command a name you can remember its function by.
    When adding commands to the batch process you'll be able to use the one
    you just created to resample your images to 72 PPI.
    Linda Rathgeber [PVII] **Adobe Community Expert-Fireworks**
    http://www.projectseven.com
    Fireworks Newsgroup: news://forums.projectseven.com/fireworks/
    CSS Newsgroup: news://forums.projectseven.com/css/
    Design Aid Kits: http://www.webdevbiz.com/pwf/index.cfm
    Aug 29, 2006 7:52 AM   in reply to Newsgroup_User
    feefriend wrote:
    > Thank you so much Linda!
    Sure thing. :-)
    Dec 26, 2007 1:18 AM   in reply to Newsgroup_User
    I realize I'm inquiring on an old post, but when I attempt to batch resize to 72 dpi following the prescribe method I find that it works for either portrait or landscape (whichever I was working off of), but distorts the other. So for example, it works for landscape, but distorts portrait.
    Any help would be appreciated. Thanks.
    Dec 26, 2007 6:40 AM   in reply to Newsgroup_User
    I usually have two different jobs for resizing horizontal and vertical
    pictures.
    alex
    Dec 26, 2007 8:47 AM   in reply to Newsgroup_User
    Yeah, I've done the same thing. Isn't there some way to perform a 72 dpi batch resize regardless of the orientation?
    Oct 31, 2013 11:54 AM   in reply to PJChoo
    did you guys come up with in answer to this.  I'm needing my pngs to be 300 dpi for a banner (6' x 2') I'm creating, I didn't know fireworks only goes to 10000 pixels.  So I can't image resize resolution.  I currently have the resolution at 100dpi.  I have both illustrator and photoshop, but when I export the fireworks as a psd file then in photoshop change the resolution it makes my layers not as clear (in other words the individual layers just scale they don't change to 300dpi)  Then if I try to batch process to 300 dpi it only scales the image one direction not both.  Needing help please!
    Oct 31, 2013 11:55 AM   in reply to Newsgroup_User
