OT:Firefox 22.0
Jul 6, 2013 3:01 PM
Tags: #firefox #22.0
I just installed the latest Firefox update and Ctrl+0 (Zoom) appears to be on steroids or something. By default, zoom is cranked up at least 3 levels higher than it should be.  Obviously, not acceptable for previewing.  Even Source Code is painfully big.   Is anyone else experiencing this?
Nancy O.
    Jul 6, 2013 6:44 PM   in reply to Nancy O.
    Not seeing anything like that here...Firefox 22 running on Mac OS 10.6.8.
    Maybe check to see if some plugins are causing grief? Try disabling them and re-enabling them one at a time to narrow down a culprit (if it's the plugins). Otherwise...no idea. You didn't enable some accessibility feature of your OS by chance?
    Jul 6, 2013 6:55 PM   in reply to Nancy O.
    Jul 6, 2013 7:14 PM   in reply to Ben Pleysier
    I'm not seeing this - FF22 on Win7 32 bit, Win7 64 bit, Win8 64 bit and Mac OS 10.8.4. Zoom works as always.
    Jul 6, 2013 9:34 PM   in reply to Nancy O.
    Neither do I - it works as it should (Win 7 pro 64bit).
    FF 22 introduces a dependency on the OS's pixel density (what with all the retina like screens being introduced):
    firefox 22 is now respecting the pixel density you've set on a system level in the windows control panel > appearance > display."
    Possible solution: set layout.css.devPixelsPerPx = 1.0 in the about:config.
    It seems some extensions can cause issues now as well:
    Yes, the addon causing issues wasn't NoSqint or FullZoom, it was the Old Default Image View, used WITH NoSquint or FullZoom.
    I fixed it by turning of old image view,
    Anyway, hopefully the devs will fix this and cause less confusion.
    Jul 7, 2013 12:41 AM   in reply to Ben Pleysier
    Hello Ben,
    thanks for the hint, just a (small) shame that it takes this Add-on, IE can do that already. I used
    https://addons.mozilla.org/de/firefox/addon/nosquint/ with it's interesting gimmicks. Some of them lever DW's properties!
    By the way Nancy, there are no problems with my FF22 and my IE 10.
    Hans-Günter
