expee
LR shows one HDD twice
Jul 7, 2013 2:57 AM
Hello,
The other day something odd happened after I imported some images; after I imported them, I couldn't locate them in their regular place. They appeared to be in a different location. When I asked LR to show their actual physical location, they appeared to be physicaly located where I wanted them. And that's when I realized that LR was just showing these images as being somewhere else. Look at the image below; see "Pictures" twice? Well, that's the same hard drive. There is only one "Pictures" hdd, yet LR has started "splitting" them. I optimized the catalog hoping that would fix it, but it stayed the same. Any idea why this is happening?
Thanks!
LR 4.4
OS X 10.6.8
    Jul 7, 2013 7:55 AM   in reply to expee
    If you Right Click on each and select Show Parent Folder, what does it look like?
    Jul 9, 2013 1:05 AM   in reply to expee
    What happens if you rightclick on the two 2013 folders and select show parent folder? I think you need to keep going up in the folder hierarchy until you get to the top folder. LR should then merge them IME.
    Bob Frost
    Jul 9, 2013 4:54 AM   in reply to expee
    expee,
    I had this happen to me several times on LR 4.4 with the same version of OS X as you.  The hard drive in question was an external NAS device which had some questionable interactions with the OS to begin with, but was basically usable.  Unfortunately I never figured out exactly what triggered the problem, and I only have a fuzzy memory of how I resolved it.
    I believe what I may have done is something along these lines (but again, I can't remember exactly)
    1) Using the Finder, rename the folder.  This causes it to go missing in LR and show a question mark icon.
    2) In the LR folders panel went to the other, "main" copy of the hard drive, went to the parent folder, and used the "synchronize" command to find the folder.  Or maybe I added the folder back some other way.  I think this caused the folder to reappear in the "correct" copy of the hard drive, and for the extra copy to disappear.
    3) Renamed the folder back to my original name.
    Sorry I can't remember exactly what I did.  All I know for sure is that I forced the folder into a missing state temporarily.  The double/split HDD icons seem to be a bug of some kind.  If I were a better citizen I would have reported it to Adobe at the time!
