d mac in marin
Bridge cannot Find PS CC
Jul 7, 2013 6:26 PM
Tags: #bridge
Hello, I have loaded Bridge, PS CC and LR 5 onto my SSD drive called S, and Bridge wants to look for PS on my C drive and will not load an image into PS.  Any advice is most appreciated.
Dan
    Jul 7, 2013 6:45 PM   in reply to d mac in marin
    You are always asking for trouble if you do not use the default locations for programs.  Other programs, installers, updaters, etc. expect to find them in certain locations.  In Windows this is on drive C.
    If you are going to put your programs on a different drive or folder you must install it there.  Be aware that you will still have many files installed on the C drive.  If you install on C and move you will sever links and program will not work.
    Jul 7, 2013 7:47 PM   in reply to d mac in marin
    The usual proceedure is to install the program files on the C drive and the cache and other files elsewhere.  But not dictating what you can do, just potential problems if you deviate from the default installation location.
  • Omke Oudeman
    Nov 27, 2004
    Jul 7, 2013 11:58 PM   in reply to d mac in marin
    since CS4 this has been my protocol,
    First thing to try is reset preferences, hold down option (Mac) or control key (win) while starting Bridge and choose reset prefs. This will set the file type associations back to default and that would mean when using Bridge CC it will be pointing to PS CC
    If both Bridge CC and PS CC are on the SSD it should be possible, but if you have them both on separate drives I think Curt has a point
    Jul 8, 2013 7:01 AM   in reply to d mac in marin
    Unclear on this statement.  You direct where you want Bridge to look by clicking on drive and folder.  When you look at the Folders Panel in CC do you have the entire computer directory showing?  If not what do you see in Folders?
