TYPE tool not working Cc6
Jul 7, 2013 8:58 PM
Don't know what I've done.  Maybe if I could return the whole project to defaults I could do it.
I suddenly can't create a little text box in a column that already holds threaded text.  The layer isn't locked and it isn't a master page.
I just want to insert captions under images...  Help?
Eeeeek.  And now the little plus sign for the thread of text has disappeared.!
    Jul 7, 2013 9:22 PM   in reply to straightlife
    Do you have a text wrap applied to the images?
    Jul 8, 2013 11:21 AM   in reply to straightlife
    So you're inserting the images as inline or anchored objects? Try adding the caption and grouping with the image before inserting.
    Jul 8, 2013 1:04 PM   in reply to straightlife
    No, use the place command to place the image on the pasteboardat the edge of thepage. Make a text box for your caption there, position it and select both and group.  Does your text box end above the image and restart below? That is the only way to make it work without a text wrap on the image.
