Long Hyperlink is broken into two lines in PDF/HTML, therefore, the link can't be opened.
Jul 8, 2013 1:52 AM
A long hyper link http://docs.oasis-open.org/ebxml-msg/ebms/v3.0/core/os/ebms_core-3.0-s pec-os.html works fine in Framemaker. Because it is too long, so it is displayed in two lines in FM. "http://docs.oasis-open.org/ebxml-msg/ebms/v3.0/core/os/ebms_core-3.0-s pe" is the first line.
After conversion, when you click the link in PDF or HTML help, you are lead to "http://docs.oasis-open.org/ebxml-msg/ebms/v3.0/core/os/ebms_core-3.0-s pe" only, so the link can't be opened.
I tried Save Book As PDF and Print, both didn't work.
Could you please help identify this issue?
    Jul 8, 2013 11:12 PM   in reply to Jennifer_Wang
    Could be at some remove from your question, and I agree it's wrong that line breaks should interfere with hyperlinks … but if you're using a hyperlink to take readers to the EBMS Core spec from a .pdf why not just use "EBMS Core spec" as the link text? For readers who want, need or prefer to copy/paste the URL into their browser, you can provide the full URL in the body, as a footnote or in a "Related links" section.
    N
    Jul 9, 2013 12:32 AM   in reply to Jennifer_Wang
    Glad it helped! Here's two tips from my FM 7.0 User Guide; I think they still apply.
    • To prevent extra spacing in the hypertext command when exporting, insert your markers at the beginning of end of a word
    • Hypertext commands … can be up to 256 characters long
    Jul 9, 2013 1:18 AM   in reply to Jennifer_Wang
    Hi Jennifer,
    Did you not only place a hyperlink marker inside of the web address but also apply apply a character format to the whole text of the web address?
    In that case the whole text should serve as a hyperlink regardless of spaces or line breaks.
    This is explained in the online help:
    http://help.adobe.com/en_US/framemaker/using/WSd817046a44e105e21e63e3d 11ab7f7960b-7e83.html
    Your description sounds as if you rely only on the automatic URL detection in Acrobat. In the Acrobat preferences in the General tab there is an option "Create links from URL". Usually this is activated. It means that Acrobat tries to find out automatically what could be a web address. Often this automatic approach is not correct.
    Best regards
    Winfried
    Jul 11, 2013 11:57 PM   in reply to Winfried Reng
    You know, Winfried, I'd never even noticed there was such as thing as automatic URL detection! I'd assumed Jennifer was following the "classic" route of selecting the URL, applying a hyperlink style and setting the hyperlink command – must count as classic, because that's the way I'd do it  Thanks for this nugget of extra information.
    N
