HatrickPatrick
Flex 3.5A QTP IE Crash
Jul 8, 2013 3:59 AM
Hello
I'm experiencing a crash trying to use QTP with Flex?
Don't have this issue with Flex 4.6 but with a project using 3.6A; using QTP Essentials (Version 11.00.0.0 Build 1018) with all patches on Windows 7 (QTP Info below) and the Adobe provided plugin (for 4.X).
Compile the project with the following compiler settings:
-include-libraries "${flexlib}/libs/automation.swc" "${flexlib}/libs/automation_agent.swc" "${flexlib}/libs/qtp.swc" "${flexlib}/libs/automation_dmv.swc"
I tend to select only the Flex and Web plugins, have tried without the Web plugin but it made no difference.
When I begin recording with QTP IE crashes as soon as I click a Flex object or view a Flex object with the object inspector, oddly when IE recovers it does insert a line that correctly identifies the flex object but it'll crash again on interaction.
The crash is IE not responding and bringing up a dialog box with 'Internet Explorer has stopped working', close program will re-open the browser but the same happens.
As I say when IE comes back it does seem to have recorded the action:
Browser("MyApplication").FlexApplication("MyApplicationX").FlexTextArea("txtUserID").SelectText 0,0
Its IE 9, have tried both 64 and 32 bit versions, the event viewer just says its a fault in ntdll.dll:
Faulting application name: IEXPLORE.EXE, version: 9.0.8112.16490, time stamp: 0x51955cca
Faulting module name: ntdll.dll, version: 6.1.7601.17725, time stamp: 0x4ec49b8f
Exception code: 0xc0000374
Fault offset: 0x000ce6c3
Faulting process id: 0x63c
Faulting application start time: 0x01ce7bc9446bf6ad
Faulting application path: C:\Program Files (x86)\Internet Explorer\IEXPLORE.EXE
Faulting module path: C:\Windows\SysWOW64\ntdll.dll
Report Id: 8b9723bd-e7bc-11e2-85eb-180373e25886
Raised the issue with HP but they won't support the plugin and recommend I upgrade QTP but I just want a workaround.
QTP Info:
Product name:QuickTest Professional
Product version:11.00
Product ID:QTPRPID11.00/01
Product build:1018
Operating system:Microsoft Windows 7 Service Pack 1 (Build 7601)
Internet Explorer version:9.0.8112.16421
ALM/QC connectivity:11.51.757.0
Add-in Information:
Name
.NET
ActiveX
AIR 2.6.0
Flex 4.5.0
Java
Silverlight
Visual Basic
Web
Web Services
WPF
Hotfix and Patch Information:
Name
QTP_00699 for HP QuickTest Professional 11.00 QFE
QTPNET_00051 for HP QuickTest Professional 11.00 QFE
QTP_00709 for HP QuickTest Professional 11.00 QFE
QTPWEB_00073 for HP QuickTest Professional 11.00 QFE
QTPWEB_00078 for HP QuickTest Professional 11.00 QFE
QTPWEB_00086 for HP QuickTest Professional 11.00 QFE
QTPWEB_00090 for HP QuickTest Professional 11.00
QTPWEB_00092 for HP QuickTest Professional 11.00
QTP_00925 for HP QuickTest Professional 11.00
