Word game: Assigning letter values to movie clips
Jul 8, 2013 11:14 AM
Hi
I want to make a word game for kids.
A spelling word will appear on the screen (from arrays that I will set up) and then letters will "fall" from the top. The player will have to clicl on the correct letter to get points. In other words:
if letters in word == letter tile clicked on
    then give points
I have movie clips in individual .as classes for each letter tile. My question is - how do I define the letter tile Movie Clip as a specific letter in the alphabet for my code to be able to check if it is correct?
Here is the .as file one of the letter tiles I have as an example:
package
    import flash.display.MovieClip;
    public class T extends MovieClip
            public function T()
                // constructor code
Charine
    Jul 8, 2013 11:38 AM   in reply to Charine -FB buggoop
    You can assign a variable to the object either dynamically (since it is a MovieClip object) or you can formally build that variable into the class and assign it a value.  THen when you want to check it you just test that object's variable (property) to see if it fits the solution.
    Jul 11, 2013 6:16 PM   in reply to Charine -FB buggoop
    You do not want to name the property the same thing as the class.  You want to name it something that will be the same for all of your letter classes so that you can test for it generically.  Something like the following would be more appropriate....
          public var letter:String = "t";
    Jul 21, 2013 8:03 AM   in reply to Charine -FB buggoop
    Here is one of the basic ways to implement this kind of game.
    There are 4 classes involved - SpellingGame, SpellingLetter, LettersAnimator, Shuffler. Class SpellingGame is a document class. This is a pure AS3 solution - no additional timeline visuals or coding needed.
    Class SpellingGame
    package
              import flash.display.Sprite;
              import flash.events.Event;
              import flash.events.MouseEvent;
              import flash.geom.Rectangle;
              import flash.text.TextField;
              import flash.text.TextFieldAutoSize;
              import flash.text.TextFormat;
              public class SpellingGame extends Sprite
                        private var words:Array = ["dog", "cat", "apple", "orange"];
                        private var guessWord:String;
                        private var wordDisplay:TextField;
                        private var _score:int = 0;
                        private var scoreDisplay:TextField;
                        private var letters:LettersAnimator;
                        private var playButton:Sprite;
                        public function SpellingGame()
                                  init();
                        private function init():void
                                  drawWord();
                                  drawScore();
                                  drawAnimator();
                                  drawPlayButton();
                        private function drawPlayButton():void
                                  var buttonLabel:TextField = new TextField();
                                  buttonLabel.multiline = buttonLabel.wordWrap = false;
                                  buttonLabel.defaultTextFormat = new TextFormat("Arial", 12, 0xffffff);
                                  buttonLabel.autoSize = TextFieldAutoSize.LEFT;
                                  buttonLabel.text = "play again";
                                  var margin:int = buttonLabel.x = buttonLabel.y = 4;
                                  playButton = new Sprite();
                                  playButton.mouseChildren = false;
                                  playButton.buttonMode = playButton.useHandCursor = true;
                                  playButton.graphics.beginFill(0x808040);
                                  playButton.graphics.drawRoundRect(0, 0, buttonLabel.width + margin * 2, buttonLabel.height + margin * 2, 10);
                                  playButton.addChild(buttonLabel);
                                  playButton.x = wordDisplay.x;
                                  playButton.y = 200;
                                  addChild(playButton);
                                  playButton.addEventListener(MouseEvent.CLICK, onPlayClick);
                                  playButton.visible = false;
                        private function onPlayClick(e:MouseEvent):void
                                  score = 0;
                                  drawWord();
                                  letters.start();
                        private function drawScore():void
                                  scoreDisplay = new TextField();
                                  scoreDisplay.multiline = true;
                                  wordDisplay.wordWrap = false;
                                  scoreDisplay.defaultTextFormat = new TextFormat("Arial", 16);
                                  scoreDisplay.autoSize = TextFieldAutoSize.LEFT;
                                  scoreDisplay.text = "Score: 0";
                                  addChild(scoreDisplay);
                                  scoreDisplay.x = wordDisplay.x;
                                  scoreDisplay.y = wordDisplay.y + wordDisplay.height + 10;
                        private function drawAnimator():void
                                  letters = new LettersAnimator(new Rectangle(0, 0, stage.stageWidth - wordDisplay.width - 10, stage.stageHeight));
                                  letters.x = wordDisplay.x + wordDisplay.width + 10
                                  letters.addEventListener(SpellingLetter.ANSWER, onAnswer, true);
                                  letters.addEventListener(LettersAnimator.FINISHED, onFinished);
                                  addChild(letters);
                                  letters.start();
                        private function onFinished(e:Event):void
                                  if (score != guessWord.length)
                                            scoreDisplay.text = "Sorry, you have lost!";
                                  playButton.visible = true;
                        private function onAnswer(e:Event):void
                                  var re:RegExp = new RegExp(SpellingLetter(e.target).letter, "gi");
                                  var obj:Object = re.exec(guessWord);
                                  while (obj) {
                                            wordDisplay.setTextFormat(new TextFormat("Arial", 16, 0xff0000, true), obj.index);
                                            obj = re.exec(guessWord);
                                  score += guessWord.match(re).length;
                        private function drawWord():void
                                  if (!wordDisplay) {
                                            wordDisplay = new TextField();
                                            wordDisplay.multiline = wordDisplay.wordWrap = false;
                                            wordDisplay.defaultTextFormat = new TextFormat("Arial", 16);
                                            wordDisplay.autoSize = TextFieldAutoSize.LEFT;
                                            wordDisplay.x = wordDisplay.y = 10;
                                            addChild(wordDisplay);
                                  Shuffler.shuffle(words);
                                  wordDisplay.text = guessWord = words[0];
                        private function get score():int
                                  return _score;
                        private function set score(value:int):void
                                  _score = value;
                                  scoreDisplay.text = "Score: " + value;
                                  if (score == guessWord.length) {
                                            words.shift();
                                            scoreDisplay.text = "YOU WON!";
                                            letters.stop();
    Class SpellingLetter
    package
              public class SpellingLetter extends Sprite
                        public static const ANSWER:String = "answer";
                        public var letter:String;
                        private var textField:TextField;
                        private var color:uint;
                        private var side:Number = 30;
                        public function SpellingLetter(letter:String)
                                  this.letter = letter;
                                  addEventListener(Event.ADDED_TO_STAGE, init);
                        private function init(e:Event):void
                                  addEventListener(MouseEvent.CLICK, onClick, false, 1);
                                  buttonMode = useHandCursor = true;
                                  color = 0xffffff * Math.random();
                                  destroy();
                                  drawText();
                                  drawBackground();
                        private function onClick(e:MouseEvent):void
                                  dispatchEvent(new Event(ANSWER));
                        private function drawBackground():void
                                  graphics.lineStyle(1, color, 1, true);
                                  graphics.beginFill(0xffffff - color);
                                  graphics.drawRoundRect(0, 0, side, side, 10);
                        private function drawText():void
                                  textField = new TextField();
                                  textField.defaultTextFormat = new TextFormat("Arial", 18, color);
                                  textField.multiline = textField.wordWrap = false;
                                  textField.autoSize = TextFieldAutoSize.LEFT;
                                  textField.text = letter.toUpperCase();
                                  addChild(textField);
                                  textField.x = (side - textField.width) * .5;
                                  textField.y = (side - textField.height) * .5;
                        public function destroy():void {
                                  if (textField) {
                                            removeChild(textField);
                                  graphics.clear();
    Class LettersAnimator
    package
              import flash.events.TimerEvent;
              import flash.utils.Timer;
              public class LettersAnimator extends Sprite
                        public static const FINISHED:String = "finished";
                        private var letters:Array;
                        private var movingLetters:Array;
                        private var timer:Timer = new Timer(1000);
                        private var bounds:Rectangle;
                        public function LettersAnimator(bounds:Rectangle)
                                  this.bounds = bounds;
                                  letters = [];
                                  for (var i:int = 65; i < 91; i++)
                                            letters.push(new SpellingLetter(String.fromCharCode(i)));
                                  Shuffler.shuffle(letters);
                        public function start():void
                                  init();
                                  movingLetters = [];
                                  timer.addEventListener(TimerEvent.TIMER, drawLetter);
                                  timer.start();
                                  addEventListener(Event.ENTER_FRAME, onFrame);
                        public function stop():void
                                  removeEventListener(Event.ENTER_FRAME, onFrame);
                                  while (movingLetters.length > 0)
                                            var letter:SpellingLetter = movingLetters.shift();
                                            if (contains(letter))
                                                      removeChild(letter);
                                  dispatchEvent(new Event(FINISHED));
                        private function onFrame(e:Event):void
                                  for each (var letter:SpellingLetter in movingLetters)
                                            letter.y += 1;
                                  if (letter && letter.y > bounds.height)
                                            stop();
                        private function drawLetter(e:TimerEvent):void
                                  var letter:SpellingLetter = letters.shift();
                                  letter.addEventListener(MouseEvent.CLICK, onClick);
                                  letter.cacheAsBitmap = true;
                                  addChild(letter);
                                  letter.y = -letter.height - 6;
                                  letter.x = (bounds.width - letter.width) * Math.random();
                                  movingLetters.push(letter);
                                  if (letters.length == 0)
                                            timer.stop();
                                  var letter:SpellingLetter = e.currentTarget as SpellingLetter;
                                  movingLetters.splice(movingLetters.indexOf(letter), 1);
    Class Shuffler
    package
              public class Shuffler extends Object
                        public static function shuffle(a:Array):void
                                  for (var i:int = a.length - 1; i >= 0; i--)
                                            var r:int = Math.floor(Math.random() * (i + 1));
                                            var t:Object = a[r];
                                            a[r] = a[i];
                                            a[i] = t;
    Jul 23, 2013 5:09 AM   in reply to Charine -FB buggoop
    Hi Charine,
    I am happy you find it useful.
    Sep 25, 2013 5:56 PM   in reply to Andrei1
    Please don't be afraid to do this again... This is brilliant, took me a guess on how to implement it, and it shows me once more how much I don't know (thanks - needed that) but this has given me a greater on class programming etc etc and some particular things I have been putting lots of hours to without prior progress. Very good, thank you.
