Will InDesign CC update placed Word docs?
Jul 8, 2013 11:42 PM
Tags: #word #update #indesign #synchronize #incopy #place #ms
Products:
MS Word 2013
InDesign CC
InCopy CC
Hi everyone.
I have a collection of chapters in MS Word format (2013 .docx version) that contain citations, endnotes, and includes an extensive bibliography.
I know that if I place an InCopy (IC) doc into InDesign (ID), any updates I make in either version of the file are automatically synchronized. For this reason, I really prefer to use InCopy... but ID and IC are a bit weak when it comes to endnotes and bibliographies.
I recently placed a Word doc into ID, updated the text within ID, saved the doc, closed the doc, and then opened the Word doc. The Word doc remained unchanged and did not reflect the changes I made to the placed version of the text within ID.
Is it possible for me to place a Word doc into ID and have it automatically update with any changes I make to its text while in ID, like what happens with IC files?
    Jul 9, 2013 1:01 AM   in reply to Stephen Buck
    It depends on your settings in the program preferences:
    Preferences > File Handling > Create Links when placing text and spreadsheet files.
    If this option active changes of Word Documents will be updated (and edits in InDesign will be lost completely).
    Jul 9, 2013 4:01 AM   in reply to Stephen Buck
    If by this you mean can edits made in ID be transferred back to word, then no.
    Jul 9, 2013 7:23 AM   in reply to Willi Adelberger
    The problem is that all formatting will be lost when updating the text. There is a third party plug-in that preservers formatting and works like a charm: Em software Wordsflow. It is not cheap however, 200 dollars and also not yet compatible with CC (latest supported version is CS6).
    info: http://www.emsoftwarestore.com/wordsflow.html
    Do you need to have a workflow like this on a regular basis I advice you to take a look at InCopy, now part of the CC.
    Jul 9, 2013 7:37 AM   in reply to Stephen Buck
    It occurs to me that while you cannot do an automatic update from ID back into the Word file, you can, at any point, export the story from ID to RTF, if that would be "good enough."
    Oct 15, 2013 9:48 AM   in reply to Stephen Buck
    Hello, Stephen,
    it will be possible in InDesign CC with this plugin called WordsFlow, when they release it specially for CC.
    Now it supports only CS5–CS6 versions of InDesign.
