Problem making ePub from Indesign Book
Jul 9, 2013 9:08 AM
I have created a book (indb) file in InDesign CC which contains 152 document (indd) files.
When I try to export the book to ePub, will only create the ePub using the first 143 documents.
I get the following InDesign error message:
"The file was exported but one or more problems were detected:
Documents : 9 skipped. (Documents not found or received errors during export.)"
Preflighting the book for digital publishing shows no errors.
Export to PDF is fine.
Any ideas??
    Jul 10, 2013 11:48 PM   in reply to POzzie469
    Please try exporting the same book to EPUB again but reduce the number of documents to 150 and share the results. If some documents get skipped now also, please share the exact error message that comes during export.
    Regards,
    Pooja
    Jul 25, 2013 11:18 AM   in reply to POzzie469
    I have never exported an epub, but maybe you should split in half and see if you get an error and try tracking that way.
    Aug 1, 2013 2:48 AM   in reply to 33 Steps
    Thanks for reporting the issue.We are able to reproduce this problem and tracking this issue via our internal bug database.
    Regards,
    Pooja
    InDesign QE
Bookmarked By (1)
