vinncero
Adobe audition cs6 play problem
Jul 9, 2013 9:46 PM
Hello!
i've just installed audition cs6, but when i open a song and hit the play button nothing happen, if i want to create a tone, same thing, i just cannot play anything on cs6, i have windows 8 and i updated audition to the latest version, what is the problem ?
Maybe it's a windows 8 problem, that wouldn't be the fist time, but i check the technical preferences and windows 8 is there, i've changed some settings in the audio hardware (in the preferences menu) but still nothing, i still cannot play something in cs6
Can somebody help me to solve this 'bug...'
Thank you
Stephan
you can email me at decamenotap@hotmail.com
    Jul 10, 2013 9:03 AM   in reply to vinncero
    Hi Stephan
    Have you checkedt that your audio interface is setup correctly in Preferences.
    Select Preferences in the Edit Window and then Audio interface
    make sure which device is selected. if you have an external audio interface
    make sure this is selected and that the type is Asio not MME.
    I haven't had experience with Windows 8, but this was often a problem with
    XP, Vista and Windows 7.
    Hope this is of some help
    Cheers
    Jul 11, 2013 1:33 AM   in reply to vinncero
    Hi Stephan
    Thank you for the additional information on your sound card.
    it is always helpful to give as much information as you can about your setup so that
    people can give you more appropriate help.
    Are you on CS6 Adobe,this supports MME cards.
    If you are on CS6, go to edit, preferences, Audio Hardware,
    MME should be shown as the device class.
    Below this your Default input and output should be your Soundblaster sound card.
    The Master clock should also be the Soundblaster, if you haven't got any additional cards
    attached to your computer the Soundblaster should be the only option.
    Set the latency to 200 and the sample rate to 48,000, The Soundblaster cards are usually set to 48Khz
    sample rate, so make sure this is selected.
    Then go to Audio Channel mapping and make sure that the input is showing Soundblaster for both left and right
    channels.
    The output should be set the same,depending on the model of card,both input and output may show
    more inputs and outputs, Always select input Channel 1 Left (Mono) and Channel 2 Right
    Hope this helps
    What you need to do is to download Asio4all from the internet,
  • SteveG(AudioMasters)
    Oct 26, 2006
    Jul 11, 2013 1:50 AM   in reply to HistoryRecordist
    I'm afraid that I don't hold out a lot of hope for a good result with any Creative Labs devices, certainly not with later OS's. Their devices are of 'gamer' quality, and there have been a lot of reports of trouble with their ASIO drivers, so MME is the best you can hope for. One of the big problems is that they won't update drivers properly for new OS's because they've realised that if they don't, then they can force people to purchase new hardware, and that's what keeps them in the extremely dubious business they're in.
    If you look back through the annuls of this forum, you'll find any number of people who have had difficulties with Creative Labs sound devices - they really aren't very good. On top of that, they've had a legal class action case go against them for telling lies about the specifications of their devices.
