x1713051
Bridge Collections
Jul 10, 2013 8:10 AM
Tags: #bridge
I have created a collection of 127 images in Bridge 5.5.  Images added beyond 127 persist for the duration of the session, but dissappear when Bridge is closed.  Is there a limit to collection size?
  • Omke Oudeman
    Nov 27, 2004
    Jul 10, 2013 9:08 AM   in reply to x1713051
    No, not to my knowledge. Collections have always been troublesome in Bridge and you must not rely on them solely If you have put a lot of work in a certain collection also use either labeling, renaming but most easiest is add a keyword to all the collected files so when in trouble you can always revert to it via the 'back door'
    Meanwhile check if you have no strange characters in the filename like ' or / etc because that could be also causing troubles.
    Also check if you have the correct read and write permission for the files, folders and disks you are using.
    And maybe try a reset of the preferences which can cure the strangest of problems.
    Jul 10, 2013 12:22 PM   in reply to x1713051
    I've had over 9000 in a collection.
