AE CC Render error output module failed
Jul 10, 2013 7:03 PM
Hi, I tried my best to find this answer on the forums but couldn't find anything current.
I have isolated two issues in AE CC where I can duplicate a failed render with this message:
After Effects error: Rendering error while writing file "xxx". An output module failed. The file may be damaged or corrupted. (-1610153464)
This happens when opening an AE CS6 project and trying to render a simple comp with only one text layer and a moving mask. It also just happened after my first round trip test with Cinema 4D. I could RAM preview the c4d layer but the output to Quicktime h.264 failed.
I have even tried a full reinstall of AE CC. I have the basic FxFactory Pro plugins and MagicBullet Looks installed, but neither are being used since this is a single 1280x720 comp with a single C4D layer. Plus like I said it failed with the same error in past CS6 files.
I don't know how to force disable a plugin to test that, but I can't see how an unused plugin could cause a render to fail like this.
I'm on a new (late 2012) 27" iMac
3.4 GHz Intel Core i7
8GB RAM
NVIDIA GeForce GTX 680MX with 2GB VRAM
OS X 10.8.4
AE CC 12.0.0.404
CUDA driver 5.0.59
Thanks for any suggestions!
Matt
    Jul 10, 2013 7:05 PM   in reply to Matt Christensen
    See the part on this page about the QuickTime H.264 codec failing with a large number of threads:
    http://blogs.adobe.com/aftereffects/2011/02/troubleshooting-quicktime- errors-with-after-effects.html
    Why are you using H.264 in a QuickTime container, anyway?
    Jul 11, 2013 11:02 AM   in reply to Matt Christensen
    Well, for one thing, there is the issue that I mentioned regarding the codec not being able to handle large numbers of threads (and therefore failing on many modern computers).
    Also, there are  many reports of bad results using this codec, including color shifts and artifacting.
    This isn't a general complaint about QuickTime---just about this one codec, which is not Apple's strongest work.
    In general, for H.264 export, we recommend using Adobe Media Encoder and its H.264 encoding presets. (Just make sure that you've installed the latest updates.)
    Jul 11, 2013 3:59 PM   in reply to Matt Christensen
    I'm having the same error when I use Quicktime as render output. Sometimes it helps when I restart After Effects CC, but after one or two renders, the error returns. The condec doesn't make a difference, Animation, Apple ProRes, all having problems. Rendering as images sequences or MXF do work.
    After Effects CS6 works great! No errors when using the Quicktime render output.
    Hope someone can help me out with this. Thanks!
    Olaf
    My system:
    Apple Mac Pro 12-core 2,66 Ghz
    OSX 10.8.4
    32 GB Ram
    Ati Radeon HD 5870 1024MB
    No Blackmagic or Aja card installed
    Aug 7, 2013 12:56 PM   in reply to Matt Christensen
    Here is a new artice from us about solutions for problems with QuickTime files in After Effects CC (12.0): http://bit.ly/QT_AE_CC_12
    Oct 15, 2013 2:10 PM   in reply to Kreukvrij
    Yep, I'm having the same issue. AE CS6 works fine, but the new version gives this bogus error message. Looks like Adobe needs to fix this bug with an update ASAP!
