How verify the message sent to my-secure-amf channel
Jul 10, 2013 8:03 PM
Tags: #https #flex4.5 #flex4.6 #jboss #jaas
Hi all,
My problem is a bit odd.
We built an application on RemoteObject + BlazeDS + Java EJB (JAAS required).
There are two target deployment environments, WebSphere 7 and JBoss 5.1.0 GA and both environments work well under HTTP.
Now we want to support HTTPS and we got a problem only happend to JBoss as following.
  • No matter what HTTPS port is used, FireFox could access the application without any issue.
  • IE8 only works fine when using default 443 as HTTPS port.
  • Debug mode could not work with HTTPS even default port 443.
I have set the logger BlazeDS to Info level and information output in console when successfully accessing. When I set HTTPS port other than 443, there is no any output from BlazeDS.
I have very concern about the client side not send proper message to correct port.
I really appreciate that someone could tell me how to verify where message is sending.
We have configured two channel my-amf and my-secure-amf and configured as default channels in remote-config.xml.
service-config.xml
    <security>
        <login-command class="flex.messaging.security.WebSphereLoginCommand" server="WebSphere"/>
        <login-command class="flex.messaging.security.TomcatLoginCommand" server="JBoss"/>
        <security-constraint id="web-access">
            <auth-method>Custom</auth-method>
            <roles>
                <role>WebAccessor</role>
            </roles>
        </security-constraint>
    </security>
    <channels>
        <channel-definition id="my-amf" class="mx.messaging.channels.AMFChannel">
            <endpoint url="http://{server.name}:{server.port}/{context.root}/messagebroker/amf" class="flex.messaging.endpoints.AMFEndpoint"/>
            <properties>
                <polling-enabled>false</polling-enabled>
                <!-- HTTPS requests don't work on IE when pragma "no-cache" headers are set. -->
                <add-no-cache-headers>false</add-no-cache-headers>
                <!-- Use to limit the client channel's connect attempt to the specified time interval. -->
                <connect-timeout-seconds>5</connect-timeout-seconds>
                <login-after-disconnect>false</login-after-disconnect>
                <invalidate-session-on-disconnect>true</invalidate-ses sion-on-disconnect>
                <serialization>
                    <ignore-property-errors>true</ignore-property-erro rs>
                    <log-property-errors>true</log-property-errors>
                </serialization>
            </properties>
        </channel-definition>
        <channel-definition id="my-secure-amf" class="mx.messaging.channels.SecureAMFChannel">
            <endpoint url="https://{server.name}:{server.port}/{context.root}/messagebroker/amfsecure" class="flex.messaging.endpoints.SecureAMFEndpoint"/>
            <properties>
                <connect-timeout-seconds>10</connect-timeout-seconds>
                <serialization>
                </serialization>
            </properties>
        <channel-definition id="my-polling-amf" class="mx.messaging.channels.AMFChannel">
            <endpoint url="http://{server.name}:{server.port}/{context.root}/messagebroker/amfpolling" class="flex.messaging.endpoints.AMFEndpoint"/>
            <properties>
                <polling-enabled>true</polling-enabled>
                <polling-interval-seconds>4</polling-interval-seconds>
            </properties>
    <channels>
remote-config.xml
    <adapters>
        <adapter-definition id="java-object" class="flex.messaging.services.remoting.adapters.JavaAdapter" default="true"/>
    </adapters>
    <default-channels>
        <channel ref="my-amf"/>
        <channel ref="my-secure-amf"/>
    </default-channels>
    <!-- enable security for all service calls -->
    <default-security-constraint ref="web-access"/>
