dy14
CS6 64-bit Bridge crashes on opening
Jul 11, 2013 6:56 AM
Tags: #error #bridge #cs6 #64bits_cs6
New install on a Windows 7 professional machine, using direct download from Adobe.  I have Photoshop CS5 which I left alone and installed CS6 as new.
Photoshop CS6 64bit launches OK but when I select Browse in Bridge I got an appcrash.  I applied the Bridge 64bit update and get the same crash:
Problem Event Name: APPCRASH
Application Name: Bridge.exe
Application Version: 5.0.1.23
Application Timestamp: 505aad8f
Fault Module Name: Bridge.exe
Fault Module Version: 5.0.1.23
Fault Module Timestamp: 505aad8f
Exception Code: c0000005
Exception Offset: 0000000000382eca
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 2057
Additional Information 1: 7af2
Additional Information 2: 7af2d3f7c9fd605d14593b6d9bf7b62e
Additional Information 3: a687
Additional Information 4: a687793695250e8a335338b274741d25
The same happens if I open Bridge 64 directly.
If I try holding CTRL down, i get the preferences window but clicking any combination of  the three options and  continuing gives exactly the same error.
I've searched for solutions and see that this complaint has been going for some considerable time..
What do i do?
    Jul 11, 2013 7:15 AM   in reply to dy14
    Did you install PS as a defalult installation on drive C, or did you install with user options?
    Did you move any install files after installation?
    Early on this was a problem when user moved Temp file off of drive C.  But that was fixed in later versions.  In PS go to help/updates and update to recent versions.
    Jul 11, 2013 9:13 AM   in reply to dy14
    This is confusing.  Do you get same result if you launch from PS?
    Don't fall into trap of unistalling CS5, there should be no conflict.  But do open Task Manager and click on Processes TAb.  Check for any instance of Bridge.exe.  If found close.  CS5 Bridge may be running in background, although this should not cause crash.
    I assume CS5 Bridge works normally?
    Jul 13, 2013 8:10 AM   in reply to dy14
    This seems really odd.  Normally uninstall and reinstall is not my recomendation, but in this case don't know what is left.  May be an installation problem.
