Aur15
Writing an image to PDF
Jul 11, 2013 10:44 AM
Hi everybody,
I encountered a problem when writing a pdf file in Flash Builder. I need to save some images from jpg/png files, but the method:
pdf.addImage(image, null, 20, 200);
requires the image to be a DisplayObject, which I do not know how to obtain from my jpg/png files.
I would be extremely grateful if you can give me a suggestion. Thank you!
    Jul 12, 2013 1:53 AM   in reply to Aur15
    Hello!
    You don't write what library you are using for export image to PDF, but I can suggest that is AlivePDF.
    If it true and your image is valid png/jpg file in ByteArray you can try to use addImageStream method like that:
    pdf.addImageStream(image, ColorSpace.DEVICE_RGB, new Resize(Mode.NONE, Position.LEFT), 0, 0, 20, 200);
    Jul 12, 2013 3:32 AM   in reply to Aur15
    For example, you can load image by using Loader/URLLoader. After this you will have a Bitmap instance with your image. And then you can use addImage(bitmap...).
    Jul 15, 2013 10:55 PM   in reply to Aur15
    pdf.save can performed before pdf.addImage in your code. Maybe this is reason why it don't work.
    Try to put
    var bytes:ByteArray = pdf.save(Method.LOCAL);
                                            fs.writeBytes(bytes);
                                            fs.close();
    after
    pdf.addImage(image, null, 20, 20);
