HELP When I opened Premiere Elements 10 half of the picture is blocked out
Jul 11, 2013 4:50 PM
Tags: #problem #help #premiere_elements #elements_10 #blue_screen_key #block_out
I have spent ages on this movie and all of a sudden half of the pictures I have blue screened on are blocked out. I thought it just hadn't loaded properly so I reopened it and uploaded it to youtube but it still stayed the same. It has been fine until now What has happened and what can I do please???????
    Jul 11, 2013 4:57 PM   in reply to hamishandandyarecool
    You may be the 3rd today with the Windows Update issue. Please check out the following to see if any of that applies to you.
    http://forums.adobe.com/thread/1252167?tstart=0
    http://forums.adobe.com/thread/1252804?tstart=0
    I wonder though since your screenshot does not seem to look like the other 2 who had the issue described in the thread cited.
    Please let us know the outcome.
    Thanks.
    ATR
    Jul 11, 2013 6:03 PM   in reply to hamishandandyarecool
    Your issue is not fitting the mold of the other two, but, if you find the kb2803821 mentioned, I would give it a try.
    Once we rule out the kb influence, then we can look at your issue from a different angle, including clarification on the relationship of the screenshot posted to "half the picture is blocked out".
    We will be watching for the follow up and be ready for alternative resolutions, if needed.
    Thanks.
    ATR
    Jul 12, 2013 5:09 AM   in reply to hamishandandyarecool
    Thanks for reporting back. It is very helpful to know that the effects of the update are not just limited to 'top half' of the screen problems.
    Cheers,
    Neale
    Insanity is hereditary, you get it from your children.
    Jul 12, 2013 6:41 AM   in reply to hamishandandyarecool
    hamishandanydandyarecool
    Great news. And, its extends the information on the issues raised by this kb update.
    Thanks for the follow which is important to us all.
    Continued success.
    ATR
    Jul 12, 2013 8:03 AM   in reply to A.T. Romano
    hamishandanydanyarecool
    You are never going to believe this.
    Up to the last time I used my Windows 7 64 bit computer with Premiere Elements (about 1 am this morning), I was having no problem with the display.
    Just now I went to do some troubleshooting with a .wmv file that I use all the time for mini test runs only to get 1/2 the display.
    Windows Updates
    and what was described as
    Microsoft Windows
    Security Update for Microsoft Windows (KB2803821)
    7/11/2013
    was found and deleted and solved the problem. Apparently the KB number is different in Windows 7 than XP. In my Window 7 64 bit, the KB number to be deleted was KB2803821. In Windows XP, I was told it is KB2834904.
    ATR
    Things are now back to normal.
    Jul 12, 2013 11:37 AM   in reply to A.T. Romano
    Adobe have now issued a help bulletin "WMV files corrupted on import or export". Maybe the Announcement at the top of the forum page could be updated to link to the bulletin.
    Cheers,
    Neale
    Jul 12, 2013 12:03 PM   in reply to nealeh
    Nealeh
    Hunt was the one who was behind setting up the Announcement last night about this matter when I asked him about distributing the information long term. He should see your post and add that to the Announcement if he has not already.
    ATR
    Jul 12, 2013 12:08 PM   in reply to nealeh
    Neale,
    Done.
    Thank you,
    Jul 12, 2013 12:45 PM   in reply to Bill Hunt
    Hunt,
    Thanks.
    I am not sure of the Adobe approach of rolling back the Updates to get rid of that one KB security update..
    If found it easier to delete the specific KB that was applicable to my computer operating system.
    ATR
    Add On...In spite of the Announcement, a new 1/2 Missing WMV post has appeared moments ago.
    Jul 12, 2013 12:51 PM   in reply to A.T. Romano
    I do not use WMV's that often, so had not seen this problem, until posted about. Checked, and yes, I had that issue too.
    I just rolled back to my last System Restore Point, and all is fine. I will just ignore the MS message, that I have have Updates to download and install - been there, done that.
    Jul 12, 2013 12:52 PM   in reply to Bill Hunt
    Also, see Peter Garaway's Reply # 20, in this PrPro thread: http://forums.adobe.com/message/5500604?tstart=0#5500604
    Jul 13, 2013 9:17 PM   in reply to hamishandandyarecool
    I just checked, and, so far, for me, the problem has not returned since I removed the Windows 7 version of that KB. If I recall, the KB was further down in the Microsoft Windows Security Updates for Microsoft Windows section. I think it was dated 07 12 2013. Did you search the whole list?
    When I corrected the situation for my wmv in my Windows 7 64 bit computer environment, I deleted just the KB cited. I did not roll back the works that were downloaded and installed that day.
    If it is back in another one of those updates, the threads should be piling up in the next several hours.
    I will be watching for further developments.
    Thanks for the alert. Wish I had better news for you. Let us see what the next hours turn up.
    ATR
    Jul 14, 2013 7:08 AM   in reply to hamishandandyarecool
    IT'S BACK.
    I started my day to find my 1/2 wmv display in Premiere Elements 11, Windows 7 64 bit.
    I went to Windows Updates, found the kb2803821 which is the one for Windows 7, deleted that kb, and now everything is back to normal.
    I thought that I had set for a notification before installation of these updates, so I need to figure out what happened to make it possible for  this kb show up here without notification as requested in the option choices for Windows Updates.
    Please let us know if you found the kb and deleted it again.
    Thanks.
    ATR
    Jul 14, 2013 7:57 AM   in reply to A.T. Romano
    Right-click the update and select 'Hide update'. It will never try to install that update again.
    Cheers,
    Neale
    Jul 14, 2013 8:03 AM   in reply to hamishandandyarecool
    hamishandandyarecool wrote:
    When I tried to delete kb2803821 again I couldn't find it,
    Open 'View installed updates'.
    Search for KB2803821 using the box at the top right of your screen
    Cheers,
    Neale
    Jul 14, 2013 8:33 AM   in reply to nealeh
    nealeh
    That might be helpful if I had the opportunity to do so.
    But, I have the Updates marked for notification before downloading and installing, and I received no notification for permission to download that kb nor did I give permission to install it at any time.
    The puzzlement is that the option seems to be working in that I see "Important" updates and other that are being held in Windows Updates awaiting my OK. In spite of that the kb2803821 seems to be slipping through this setup.
    ATR
    Jul 14, 2013 5:17 PM   in reply to hamishandandyarecool
    Nealeh shows that in post #17.
    In my Windows 7 64 bit,
    Start Button
    In Search Programs and Files field, type Windows Update
    After you do that, in the upper part of that left column, look for Check for Updates and click on it.
    In the Windows Update page that opens,  there are Important and optional updates. Click on Important to reveal those there. If you see the one in question, then right click it and select Hide as in Nealeh's screenshot.
    I think that is the intent.
    My problem is that the kb is not showing up in that area for me to hide it. Need to figure out why not. Right now I am on a wait and see for a 3rd return of that kb and its consequences.
    ATR
    Jul 15, 2013 2:53 AM   in reply to A.T. Romano
    After you've uninstalled the update you have to wait for it to show up as an install candidate again before you can hide it.
    Rather than waiting, the quickest way to bring it back, so that it can be hidden, is to go to Windows Update and manually 'Check for updates'.
    Cheers,
    Neale
    Jul 15, 2013 6:52 AM   in reply to nealeh
    nealeh
    In response to your post 22 to me, I know all that. Been there and done all that. So, far 7 12 2013, 1/2 wmv display/kb deleted; 7 14 2013 and as before got downloaded and installed without any notification that it was downloaded and/or installed - so deleted kb again. Now waiting to see if it returns on its own again 7 16 2013. I am checking the Windows Update area that you targeted  in your post 22 screenshot.
    ATR
    Jul 15, 2013 3:39 PM   in reply to A.T. Romano
    This is exactly what is happening with me.. But I did the update and nothing is happening.
    Jul 15, 2013 4:03 PM   in reply to Calyx525
    Calyz525
    Have you been following similar discussions on this matter going on in the following thread?
    http://forums.adobe.com/thread/1254296?tstart=0
    Please update on your progress when you get a chance.
    Thanks.
    ATR
    Jul 15, 2013 4:06 PM   in reply to hamishandandyarecool
    The 1/2 wmv display and that kb has not returned yet. I am watching all fronts. And, I am absorbing all the inputs and suggestions.
    Let us hope that Microsoft gives this security update material a different kb number when it "fixes" it.
    ATR
    Jul 15, 2013 4:47 PM   in reply to A.T. Romano
    ATR,
    I agree completely. That would be their normal course of action, but... ?
    When I return from Australia, I will look for my MS Updates, but not touch anything, until I have checked out the threads here, to make sure that they did fix things.
    Hope that your Win7 settings issue gets resolved. Like others, I have every program on my computers, set to do Updates ONLY manually, so that I can first create a System Restore Point, then download and install, and also know that I might have to then update my video (and maybe audio) drivers.
    Good luck to us all,
    Jul 20, 2013 7:07 AM   in reply to hamishandandyarecool
    Oh, no. But you were able to catch view of the kb and Hide it this time, thanks to nealeh's suggestion.
    Right now I am set up for notification before any Windows Updates downloading plus installing. No signs of the problematic kb yet.
    ATR
