markderutte
urgent multiclip help
Jul 11, 2013 11:41 PM
Tags: #sequence #playback #bug #project #timeline #multicam
every time I close and re-open premiere...almost every one of my multiclips seems to revert back to the slate shot. almost every clip seems to hold the same spot in which I cut but the footage is just looping and all the work has to be started over. Screen Shot 2013-07-11 at 11.39.31 PM.png
    Jul 12, 2013 12:30 AM   in reply to markderutte
    If you have not already applied the 7.0.1 update, please do so. A bug that caused a problem like what you're describing is fixed in this update. In most cases, affected multicam sequences are corrected by the fix, but some users have reported that the damage was not undone.
    Jul 12, 2013 1:25 AM   in reply to Mark Mapes
    A applied the 7.0.1 update but, I have the same problem with multicam!
    Jul 12, 2013 2:05 AM   in reply to Aandix
    Please clarify. After applying the update, did you create a new multicam sequence, record at least two passes of edits, close and reopen the project, and find that the each edit reverts to the start of the clip? Or are you reporting that the multicam sequence that you edited in 7.0 was not fixed by the update?
    Jul 12, 2013 12:39 PM   in reply to Mark Mapes
    Hi Mark. I tested now in a new sequence. It's all OK. Thank you for your answer!
