arkadiusz.bartnik
[Flash Pro CC] Bug - re-open saved fla
Jul 13, 2013 6:49 AM
Tags: #flash #bug #flash_professional #flash_cc
Hi, I found a bug in Flash CC.
When I create a FLA file in Flash CC - I can not open it later in the same program. There is information that the scene is broken. There is also available from the library elements.
The version of "Flash CC": 13.0.0.759
OS: Windows 7 SP1 x64
However, when opened in version CS6 and saved, this fla file is opened by version CC.
Has anyone had this problem? How did you solved it?
    Jul 15, 2013 4:14 AM   in reply to arkadiusz.bartnik
    Is it happening everytime for all the files that you create in Flash CC?
    Also, can you please upload the problematic file for us to take a look at it?
    Thanks!
    Mohan
    Jul 15, 2013 5:41 AM   in reply to arkadiusz.bartnik
    This is happening to all users! Why so much delay to solve this problem?!
    Jul 16, 2013 4:24 AM   in reply to arkadiusz.bartnik
    I got another problem with saving fla file in Flash CC too.
    i edited my code -> crtl + s to save -> ctrl + enter to build -> close the swf -> close the fla file -> re-open the saved fla file -> my edited code disappear
    Here is my code:
    - Before edited: count = Number(getTimer()-startTime)
    - After edited: count = totalTime  -  Number(getTimer()-startTime)
    After saving and reopen --> it displayed as before edited .
    Does anybody get the same problem?
    Jul 30, 2013 12:09 PM   in reply to Seke1412
    Im working with Flash Buldier and Flash Profesional CC.
    After lunchinng flash project, everytime in flash i got massage it can't save file (i see that another process of flash profesional cc is loocking the file).
    Saving file with another name helps a bit, but after i have to close flash and rename in explorator to orginal file (to name with i started project) to continue work.
    But... NOW i'am working on important project for several hours RIGHT NOW, and i can't open file bacause it says THE file is broken..
    I updated Flash Profesional from CS6, because of problems with windows like Actions, Timeline (atfer reopen program it forgot settings of it's positions).
    I'am user of CS5.5 and then updated to creative cloud AND FOR WHAT ? SUPPORT ?!
    Jul 31, 2013 12:54 AM   in reply to Seke1412
    If the code is placed inside your any of the movie clip we have identified there is a problem with saving them unless you modify the document. There is an update to your Flash Professional CC on the way with the fixes for important bugs. Meanwhile to workaround this issue just modify the moviclip and undo the changes before you save the document in order to preserve the script editing.
    Hope this helps.
    Thanks!
    Mohan
