tyrillhans
export multitrack
Jul 13, 2013 6:20 AM
Tags: #file #sound #multitrack #stereo #wav
I have a multitrack session with two mono .wav files in each its channel. I need to export this as one stereo .wav file, with each of the original mono files in each its channel (left and right). How do I do this?
Thank you!
Larilin
    Jul 13, 2013 6:47 AM   in reply to tyrillhans
    Maybe I'm not understanding the question but wouldn't you just pan track one to the left and track two to the right?
    Then File > Export > Multitrack Mixdown > Entire Session
    Jul 13, 2013 7:24 AM   in reply to tyrillhans
    On the 'Export Multitrack Mixdown' window select "Change" under 'Mixdown Options'
    Then select "Stereo" under the "Master" dropdown
    'Range' should be set to 'entire session'
    Jul 13, 2013 8:16 AM   in reply to tyrillhans
    Have you panned your files so one is left and one is right before you mix them down?   If not, both will be central and therefore your stereo will be two identical tracks.
    You can go hard left and hard right to get two totally discrete channels or partially L/R for a more subtle effect.
    Pan using the knob in the control section at the left end of each track.  L100 equals hard left, R100 equals hard right.
    I know you're frustrated but panning tracks is sound mixing 101 and every bit of audio software would need a similar process.
    Jul 13, 2013 9:30 AM   in reply to Bob Howes
    Are the two files in a Stereo session? If you have opened them into a Mono session then I suspect you cannot Mixdown to Stereo.
    Jul 13, 2013 10:14 AM   in reply to tyrillhans
    Its really not that hard
    I have attached an animated gif which should help with the settings
    I just started a new multitrack session (based on no template) and dragged in two mono files - one on each track
    Then panned each track - one L100 and the other R100 (left & right)
    Then exported the mix as per settings in the gif (click on it to see)
  • SteveG(AudioMasters)
    Oct 26, 2006
    Jul 14, 2013 3:47 AM   in reply to tyrillhans
    The simple answer to this is not to try to export the file at all, but just do a mixdown. If it's a stereo session, you end up with your two files where you panned them, in a stereo file.
